It seems that most times when I Delete unwanted photos from LR, those that I have black-flagged, after deleting them, LR returns a message stating "The File Could Not Be Found". Wondering what file LR is referring to.
Mar 13, 2016 17:05 | #1 It seems that most times when I Delete unwanted photos from LR, those that I have black-flagged, after deleting them, LR returns a message stating "The File Could Not Be Found". Wondering what file LR is referring to. _______________
Nogo POTN record for # of posts during "Permanent Ban" 9,193 posts Gallery: 17 photos Likes: 685 Joined Dec 2013 Location: All Along the Natchez Trace (Clinton, MS) More info Post edited over 7 years ago by Nogo. (2 edits in all) | Mar 13, 2016 17:14 | #2 Somehow you are likely deleting the files but not removing them from the catalog. If you delete it using your file browser, it will cause that problem. I don't know why it would not delete it from the catalog after flagging and deleting, but somehow it is not removing it from the catalog whatever is going on. Philip
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Mar 13, 2016 17:21 | #3 Larry Johnson wrote in post #17934189 It seems that most times when I Delete unwanted photos from LR, those that I have black-flagged, after deleting them, LR returns a message stating "The File Could Not Be Found". Wondering what file LR is referring to. If you are deleting the file from the filesystem outside of LR, then going back to LR and using the black flag you will get this result, as the file is alreadt gone.
Mar 13, 2016 18:14 | #4 Nogo wrote in post #17934198 Somehow you are likely deleting the files but not removing them from the catalog. If you delete it using your file browser, it will cause that problem. I don't know why it would not delete it from the catalog after flagging and deleting, but somehow it is not removing it from the catalog whatever is going on. BigAl007 wrote in post #17934211 If you are deleting the file from the filesystem outside of LR, then going back to LR and using the black flag you will get this result, as the file is alreadt gone. Because of the fact that LR stores all of the information about a file in it's internal database it is important that you do not make any changes to the location of the file outside of LR, including deleting or moving them to the recycle bin. LR's usual method for removing the duds is to mark them with the black flag. Once you have gone through all the images LR has a tool that will then remove all of the negativly flagged files. It also has the option to chose to remove the image from the database only, or to delete it from the disk too. Alan yeah, I'm deleting them through LR, selecting "Delete from Disk". LR5. _______________
Nogo POTN record for # of posts during "Permanent Ban" 9,193 posts Gallery: 17 photos Likes: 685 Joined Dec 2013 Location: All Along the Natchez Trace (Clinton, MS) More info | Mar 13, 2016 18:41 | #5 First thing I would try is to optimize the catalog. Then see if the problem is still occurring. I don't have a clue what is going on unless it is something strange like you are somehow deleting it while in one catalog and seeing it from another. Philip
| Latest registered member is semonsters 1689 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
