murtaugh wrote in post #17935336
Thanks for the input. I agree it is a far distance and I'm hoping I can get closer. I'll be at my first Bassmaster event next month so I'll get a better idea how close on the water I can get.
Your right I won't be going for audio right off he bat, although if I can find ways to get closer I might. I've found a few mic options and will be getting one soon to be able to get better audio for the family stuff and should the chance I get closer or get to ride along on some local tournaments I'll be ready.
The 135L at $1,000 is about the top of my range, that combined with the 80D, more memory, a mic, and few other things that might pop up.
Heya,
At close distance you can use a shotgun mic (I use a takstar). They're good at isolating dialogue from people. When doing it, you record with an amplified +10db signal and drop the low frequencies (most shotgun mics have this option on them that you can set), this way later, when you process, you can bring the audio signal down by -10db and it will be very clean sounding (and not just a bunch of wind noise). Works great.
For far distance, there's no option that is on-camera. For distance you simply need a microphone of some kind on the subject or you will not get any dialogue. If you want to just record nature's sound, that's a simple omni mic near the camera. But if you're doing people, dialogue, someone will need to wear clip-n mics if you're not near them. That simple. No fun for spontaneous stuff.
Reality is, if you're doing video of fishing and stuff, they're not wearing mics, and you're not going to capture dialog from more than 20 feet away, so you won't be doing audio for those kinds of things.
If you're going to hand-hold a lot of this, you really should look into building a DIY or buying a gimbal. Research it on google. A gimbal with image stabilization will give you a lot smoother videos before processing and processing can make them cinema-level smooth. It's the main difference between an amateur looking handicam video and something professional looking.
The longer your lens, the harder it's going to be to have smooth playback without a bunch of swaying and bobbing. Image stabilization helps, but on a telephoto, it's still very hard to not have even on a tripod. Wider angle or just shorter lenses, with stabilization, can achieve very smooth playback without too much trouble. I wouldn't try filming a fishing show with a 400mm lens for example, handheld.
Very best,
