Thread started 17 Mar 2016 (Thursday) 07:05
Does anyone have a formula for the 5DS R to give those delicious dark B&W images
Submariner
Joined May 2012
Mar 17, 2016 07:05 |  #1
OK firstly its definitely me!
But I don't seem to be able to get those besutiful, powerful, deep, deep black and white images on the 5DS R.
But then I failed on the 5DIII - this is down to me as the camera is perfect in all other respects. Actually I am delighted with it. Other than cost a firtune in computing power and storage ( but then to be expected .... High detail ... Big files ... Needs a big computer to handle it.
I shoot in RAW , and in colour, as I Was told it captures more detail this way, and convert them. Plus some dont like B&W.
Software wise I have and use Canon DPP, Photoshop Element 13 and the excelelnt Potraiture plug in.
My problem is they seem a but wishy washy or "Dark Grey & White" sums it up perfectly. IMO the colour versions are perfect for me anyway.
I cant post examples as the new workstation has its new faulty MB being replaced.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
bildeb0rg
Gallery: 821 photos
Mar 17, 2016 07:25 |  #2
i think googles' nik software plug ins work for elements, could be wrong, try their b+w presets
sapearl
Gallery: 243 photos
Post edited over 7 years ago by sapearl.
Mar 17, 2016 07:27 |  #3
What is your workflow for creating b/w conversions?
It sounds like your first step is to create the best color image you can (which is what I typically do), and then you proceed from there. Just using Photoshop I've always felt the key is to use b/w adjustment layers, playing with each color channel, erasing away various portions of the image until I get the results I want. Typically I may create 3-4 layers which to give me a pleasing range of bright highlights to dark blacks.
Are you using layers? Here is a sample using my method:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/3/LQ_781634.jpg
Image hosted by forum (781634) © sapearl [SHARE LINK]
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Mar 17, 2016 07:31 |  #4
SilverEfex Pro
https://www.google.com …products/silver​-efex-pro/ (external link)
Getting better at this - Fuji X-t5 & X-t3 - 16 1.4 - 35/50/90 f2 - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
Submariner
Joined May 2012
Mar 17, 2016 08:14 |  #5
bildeb0rg wrote in post #17938308 (external link)
Submariner
Joined May 2012
Mar 17, 2016 08:21 |  #6
sapearl wrote in post #17938310 (external link)
Hosted photo: posted by sapearl in
./showthread.php?p=179​38310&i=i257160596
forum: Canon Digital Cameras
No I am not using layers.
Pretty basic workflow, open in DPP 4 to see the raws, and choose one. Go to photoshop elements 13, open in camera raw, adj. exposure if necc, then edit say any bad skin, sharpen a little, remove all saturation, save as Jpeg. Open in Canon DPP remove all saturation again, then darken, a little, use curves to try and improve ... save
Submariner
Joined May 2012
Mar 17, 2016 08:22 |  #7
Thanks will check this out.
sapearl
Gallery: 243 photos
Mar 17, 2016 08:55 |  #8
Submariner wrote in post #17938347 (external link)
Once you get the hang of using layers there are TREMENDOUS new capabilities that become available in your editing abilities.
I don't use any plug-ins (nothing at all wrong with them any many of my friends use them with beautiful results, I'm just a s/w minimalist) but there is so much more you can do from a creative control standpoint once you start using the layers concept.
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Mar 17, 2016 09:06 |  #9
Does Elements have layers?
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Mar 17, 2016 11:07 |  #10
FarmerTed1971 wrote in post #17938395 (external link)
Yes it does.
CDS' HOT LINKS
BigAl007
Gallery: 556 photos
Mar 17, 2016 11:10 |  #11
Your problem is that you are just desaturating the image, this will always provide very poor results. I Think what you will need to do is take a TIFF into the PSE editor, rather than using ACR, as I don't think the PSE version of ACR has the Monochrome conversion option with the eight channel mixer. Also it seems to me from the way you are describing things as if you are trying to apply edits to the RAW file in DPP, followed by ACR and then back to DPP. This is not actually possible, you would have to convert to a TIFF in order to do this, maybe you are and I missed it in the description of your workflow, but I did notice you mention desaturating colours twice.
Once you have converted the image to a TIFF and opened it in the PSE editor, you would want to use ideally the Channel Mixer set to Monochrome, or the Black and White filter (the Monochrome option in ACR works the same way if you have access to it.) All of these methods for converting to black and white allow you to change the way that the various different colours are converted to shades of grey. This effectively changes the spectral response of the conversion, in much the same way as using orthochromatic or panchromatic film would, as well as mimicking the use of various different coloured filters, Yellow, Orange, Red and Green were perhaps the most common, that would have been used with black and white film.
Changing the colour channel mix has a VERY VERY BIG EFFECT on the look of your monochrome conversion. Here is an example that I picked because it has a both very bright red and blue areas in it.
Colour image.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/3/LQ_781659.jpg
Image hosted by forum (781659) © BigAl007 [SHARE LINK]
This is what you get if you simply desaturate it.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/3/LQ_781658.jpg
Image hosted by forum (781658) © BigAl007 [SHARE LINK]
I'll have to go to a second part to show the effects of using the channel mixer.
Alan
BigAl007
Gallery: 556 photos
Mar 17, 2016 11:22 |  #12
So to follow on, if I use the channel mixer I can chose to make the reds all darker, and boost the blue channel. This will have a significant effect on the image.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/3/LQ_781660.jpg
Image hosted by forum (781660) © BigAl007 [SHARE LINK]
Specifically I moved the sliders in the channel mixer (in LR in my case) so that the Red and blue were at extremes and had the rest of the slider run in a diagonal vertical line so that the other channels got more or less boost/pull. The I reversed the sliders so that the red was boosted and the blues pulled back. As you can see the toneal values are pretty much reversed in this final image.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/3/LQ_781661.jpg
Image hosted by forum (781661) © BigAl007 [SHARE LINK]
Playing with the colour sliders in which ever mixer you use can get you much better looking monochrome images than you will ever get just by desaturating.
Oh and if you are going to do this is a RAW converter as long as you have a reasonable starting point you will probably end up making significat changes to many of the settings. So getting it right in "colour" first is actually a bit pointless. One caveat is White Balance. Get a good WB first, as WB will have a significant effect on the final tonal values you will be able to get. Or of course adjusting it wildly could get you where you need to be with regards a black and white image.
Alan
sapearl
Gallery: 243 photos
Mar 17, 2016 15:45 as a reply to  @ BigAl007's post |  #13
BigAl - what a wonderful example you displayed of what I was trying to say in my modest post on using b/w conversion adjustment layers in PS. I think you said it perfectly. Many of the plugins and Nik, etc. effects offer similar results, but being a cheapskate I've always just dabbled with the sliders in PS and experimented with layers. Again, this is a terrific set of comparison images - thanks for sharing!
sapearl
Gallery: 243 photos
Mar 17, 2016 18:47 as a reply to  @ sapearl's post |  #14
To follow BigAl's instructive images I offer two more of my own. This was shot late in the afternoon with a nice soft diffuse partially cloudy sky. It is another one of Gehry's beautiful structures, this time the Peter B. Lewis School of business on the CWRU campus in Cleveland.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/3/LQ_781752.jpg
Image hosted by forum (781752) © sapearl [SHARE LINK]
sapearl
Gallery: 243 photos
Mar 17, 2016 18:55 |  #15
Here is the same image, but converted to b/w using only Photoshop, playing with the color channels in the b/w conversion menu. The stainless steel roof was similar in tone and value to the gray/blue sky and I didn't want the two blending together. I needed definition, to have them separated. To do that I created an adjustment layer just for the roof and played with the blue and cyan channel sliders until I got the desired effect.
I wanted I bit more contrast and definition on the bricks also, so I played with the red and yellow sliders on those channels until I achieved the desired level of separation. Once all was done I played with brightness and contrast, and then sharpened portions of the image. Here is the b/w result:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/03/3/LQ_781753.jpg
Image hosted by forum (781753) © sapearl [SHARE LINK]
13,309 views & 9 likes for this thread, 11 members have posted to it and it is followed by 5 members.
1277 guests, 136 members online
