im looking for a mini tripod to use so i can do macro shots. i have a canon 60d with a canon 100mm macro. and every mini tripod i try tips over from the weight. what do you guys use?
Mar 19, 2016 17:39 | #1 im looking for a mini tripod to use so i can do macro shots. i have a canon 60d with a canon 100mm macro. and every mini tripod i try tips over from the weight. what do you guys use?
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 19, 2016 18:32 | #2 Probably a bit (all right, a lot) more than you want, but I use this Jon
that little thing is a beast. i cant afford that though. lol
Mar 19, 2016 23:41 | #4 Permanent banI've always wanted one of these 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
Mar 20, 2016 16:14 | #5 Fairly similar to Jon - I use the Gitzo 3320BS. Out of print now but a great little tripod if you can find one. It supports anything, well up to about 100 kilos or so, extremely rigid and quite compact. It is total overkill for normal uses but that's just what you want for Macro! Life is for living, cameras are to capture it (one day I will learn how!).
Mar 20, 2016 20:31 | #6 i found this http://www.ebay.com …geName=STRK%3AMEBIDX%3AIT
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Mar 20, 2016 21:04 | #7 I wouldn't trust the center column, and I'd be cautious about using the legs at full extension, but bearing that in mind, it could be a start. My biggest concern would be the pan-tilt head. I rather suspect it won't hold well, since it's probably high-density poly. I don't see any reference to it being removable, which would let you upgrade to a solider (probably ball-type) head. This Jon
| Latest registered member is Marcsaa 790 guests, 142 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
