BigAl007 wrote in post #17944961
Yes I really would love a 5DS for my airshow work, where I am usually FL limited at 600mm, even on an APS-C sensor. This is the first digital camera with a 35mm format sensor that I would actually consider. I would still be happy to crop down to leave just 15×10mm of sensor, as I have to do with my current camera, and I would still have more pixels than I get with my 50D. I would also get to leave the zoom at 600mm until the image filled the full 36×24mm sensor before having to zoom out. I currently find that my 50D has both ample buffer depth, and a high enough frame rate (I usually shoot bursts on Low speed) that I don't think the 5DS would be a disadvantage. Well except the price I suppose, and I need a new computer anyway, the old one really is now suffering it's death throws.
Alan
yeah, unfortunately even 50mp is only similar in pixel density as the better canon crop sensors, so it wouldn't really offer more "reach", but it should allow for better composition given that you'll have more area to play with. also, as you said, you would have a little more freedom in how close the the plane can get before it no longer fits the frame.
you should get one--the amount of detail you get will blow your mind! also, personally, i found that the noise created, though similar in amount per pixel compared to the 7d2, is significantly less visible or distracting when viewed at the same sizes.
