FORUMS Photography Talk by Genre Bird Talk
Thread started 22 Mar 2016 (Tuesday) 17:07
Canon 7D II, 2X III, and 400/5.6
Beekeeper
Gallery: 46 photos
Mar 22, 2016 17:07 |  #1
Anyone using the 7D II, 2X III extender, and 400/5.6 Prime? Mainly trying to figure out if this combo will autofocus at F8?
Zach--C&C is welcome on my photos
https://www.flickr.com​/photos/46367607@N06/ (external link)
7DI Body Gripped|7DII Gripped|EF 85mm1.8|EF 50mm1.4|EF 100mm2.8L IS Macro|EF-S 10-22mm|EF 400mm5.6L|430EXII|580E​XII
txcanon
Gallery: 13 photos
Post edited over 3 years ago by txcanon with reason 'grammar'. (2 edits in all)
Mar 22, 2016 18:07 |  #2
Hey Zach, I don't have the 400 prime but I do have the 100-400 f/4.5-5.6L with the 7D II and 2x III.
It will not autofocus. You will need a 1 series body to autofocus with the 2X.
Brad
My Photo Gallery (external link)
Beekeeper
Gallery: 46 photos
Mar 22, 2016 18:14 as a reply to  @ txcanon's post |  #3
Thanks for the help. I'm not sure about grabbing one then.
lilkngster
Mar 22, 2016 19:03 |  #4
400mm f/5.6 with a 2xIII gets you 800mm f/11. Nobody autofocusing with that.
With the 1.4 extender you will get f/8 which is AFable if you camera can do f/8.
6dII/80d/1dIII|8mm to 400mm|Pro-10/100
johnf3f
Mar 22, 2016 19:20 |  #5
I wouldn't worry about the lack of AF too much as it should AF in Live View, however I suspect that you may not wish to keep the images - they won't be great.
If you really wan't 800mm then either spend the hideous amount of money to get the 800mm lens (it's a cracking lens - I love mine) or learn to stalk better and get closer - it takes time but it's free! As far as image Quality is concerned closer is almost always better.
Life is for living, cameras are to capture it (one day I will learn how!).
Beekeeper
Gallery: 46 photos
Mar 22, 2016 19:52 as a reply to  @ johnf3f's post |  #6
Thanks for the response. I've been hunting since I was around 7 years old, and am pretty good at being invisible. I just can't figure out how to get closer to skittish waterfowl out on lakes. An 800mm may be something I look at a few years down the road.
Motor ­ On
Mar 22, 2016 20:31 |  #7
7D2, Sigma 1.4x, 150-600 @ 600 still center point AFs at f/9 Slow but accurate. This past weekend it was easier to use it to lock onto nearby landmarks then manual focus on my target. 1/2 way through the air show I pulled the 1/4 and let the AF run the whole time. Had a few keepers and never had to sit in any of the airshow traffic. This was from multiple miles away (5-11) with the TC, AF , Recompose.
IMAGE: http://www.dcanavanphoto.com/img/s7/v153/p1979216130-3.jpg
IMAGE LINK: http://www.dcanavanpho​to.com/p551612158/e75f​87102  (external link)
How long a lens are you using now? Over water during the day, mirage is going to be an issue, getting beyond 400 it's a lot more prevalent than I ever noticed with my 300 2.8 (which took hit days and warm surfaces), and mirage will make things soft. Makes the morning and evening hours all the more important, but over water has now become a source of concern for it, so something to keep in mind.
2 threads you may want to check out about getting closer, being on the water is a lot less threatening to the wildlife apparently
https://photography-on-the.net …showthread.php?​p=17766022
https://photography-on-the.net …read.php?t=1091​924&page=1
Website (external link) | Facebook (external link) | Instagram (external link)
johnf3f
Mar 22, 2016 20:33 as a reply to  @ Beekeeper's post |  #8
I used to do a bit of Deer-stalking myself - but cameras have FAR shorter effective range. It just makes it more challenging and more enjoyable.
Beekeeper
Gallery: 46 photos
Mar 22, 2016 20:38 as a reply to  @ Motor On's post |  #9
Im currently using the Canon 400 5.6 lens, and love it.
Tom ­ Reichner
"I am a little creepy"
Gallery: 146 photos
Post edited over 3 years ago by Tom Reichner. (2 edits in all)
Mar 23, 2016 12:47 |  #10
Beekeeper wrote in post #17944810 (external link)
As lilkngster alluded to in post #4, it is impossible for that combo to autofocus at f8 because there is no such thing as f8 with that combination. The largest possible aperture with that combo is f11.
Personally, I do not like the way that the 400 f5.6 pairs with either the 1.4x or the 2x tele-extenders.
Tom ­ Reichner
Gallery: 146 photos
Mar 23, 2016 12:51 |  #11
Beekeeper wrote in post #17945009 (external link)
Trying to get close to them is very seldom, if ever, going to be effective - especially if they are game species like ducks & geese that get hunted. Rather, you wait in a blind and allow them to come close to you.
Snydremark
my very own Lightrules moment
Gallery: 47 photos
Mar 23, 2016 13:19 |  #12
Tom Reichner wrote in post #17945800 (external link)
This, really. If you are lucky, there are *some* locations where you can get close enough to the waterfowl by going to them; but, for a lot of them and in the much more rural areas, Tom's got the right of it. Some patience and and a good book or something to bide your time will do much more for your success, even with a longer lens in the mix. Here, near the coast, we have a lot of areas where we can get "at" the ducks and other water birds without them being "too" skittish; but even a few of those are tricky without spending some time sitting (grebes, in particular).
- Eric S.: My Birds/Wildlife (external link) (7D MkII/5D IV, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS I/II)
Sgt.
Gallery: 56 photos
Mar 25, 2016 17:26 |  #13
It will autofocus in live view no problem.
I have the same set up except I have the 2x mkII
Iain
7D MKII
Another minion in the Pondrader fan club
Sgt.
Gallery: 56 photos
Mar 25, 2016 18:57 |  #14
IMAGE: https://farm6.staticflickr.com/5691/21283296875_67e9a64feb_b.jpg
IMAGE: https://farm1.staticflickr.com/553/19653048989_97e5235d96_b.jpg
Iain
7D MKII
4,401 views & 12 likes for this thread
Latest registered member is Bluewonder310
2045 guests, 329 members online
