Will Photoshop CS5 with ACR version 6.7.0.339 be able to read raw files from a Canon 5D mkIII? Thanks.
Edit: I found out it will work.
cristphoto Goldmember 1,052 posts Likes: 72 Joined Feb 2010 Location: Maryland More info Post edited over 7 years ago by cristphoto. | Mar 24, 2016 14:37 | #1 Will Photoshop CS5 with ACR version 6.7.0.339 be able to read raw files from a Canon 5D mkIII? Thanks. 1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
Shooting Goldmember 1,552 posts Likes: 3 Joined Jan 2008 More info | Apr 07, 2016 18:06 | #2 cristphoto wrote in post #17947124 Will Photoshop CS5 with ACR version 6.7.0.339 be able to read raw files from a Canon 5D mkIII? Thanks. Edit: I found out it will work. Good for you.Just for your info, if you have a camera that is too modern for CS5 to handle then you use Adobe's free software DNG converter. It will convert the camera's raw files to a format of photoshop that you choose to use.
| Latest registered member is semonsters 1154 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
