Thread started 25 Mar 2016 (Friday) 11:56
Canon 7D and SoloShot, anyone?
MontanaMike
Joined Mar 2016
Mar 25, 2016 11:56 |  #1
I have a question and am getting several different views.
I have a Canon 7D. What I am trying to accomplish is to be able to attach the camera to a motorized ball head to be able to photograph birds in flight and aircraft in flight using my laptop monitor to view.
Now I know I have to be in live mode for the sensor to send image to computer. What happens is I lose the function of the AF to work. Is there a way to get the AF function to work during live view?
The motorized ball head will be controlled by a joy stick and the camera will be triggered with the shutter release trigger while I track subject using the laptop. Any suggestion?
MontanaMikes Treasure Chest
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Mar 25, 2016 12:00 |  #2
MontanaMike wrote in post #17948204 (external link)
I don't have my 7D with me at the moment, but IIRC, you have to actually enable AF in Live View; I think it's off by default.
Snydremark
Gallery: 66 photos
Mar 25, 2016 12:01 |  #3
Also, what sort of motorization are you using (this is interesting); I wouldn't think a motor would drive fast enough to follow planes/birds IF
MontanaMike
Joined Mar 2016
Mar 25, 2016 12:08 as a reply to  @ Snydremark's post |  #4
Thanks, I never shot in live mode before but being so darn shaky I thought this might be the ticket. Not sure how fast it will focus tethered to computer but I am getting closer. Thank you.
MontanaMike
Joined Mar 2016
Mar 25, 2016 12:11 as a reply to  @ Snydremark's post |  #5
Its called Soloshot.
Snydremark
Gallery: 66 photos
Mar 25, 2016 12:20 |  #6
MontanaMike wrote in post #17948220 (external link)
Makes sense; found it. You need to Enable LV AF and set it to Live Mode. You may well find, though, that it doesn't AF fast enough that way for you to be able to catch your subjects.
Ahh, ok. Looked up SoloShot...I've seen that before. I suspect that sticking a high res video cam and grabbing stills out of the video is going to be your way to go for getting shots with that setup. I love my 7Ds and 7DII, but I have a hard time imagining them working well in that configuration.
By all means, give it a try; I know what conditions you're working under, but have some moderate expectations about the performance of the setup.
Jon
Joined Jun 2004
Mar 25, 2016 16:09 |  #7
I rather suspect that the 7D in LV will be too slow focusing to give you worth-while results, even if you are able to track the birds/aircraft through a joystick, LV to a laptop (USB2, bear in mind, at best) and motorized head.
Jon
Cocker Spaniels
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Mar 25, 2016 16:23 |  #8
Heya,
It might work, but you'll obviously be shooting with a very short lens to make this work. They were designed to use their own lighter weight gear. They can be adapted to the 7D of course. But how much weight can it take? Also, how long of a lens?
If you mount a 7D on there, it will probably only work with a relatively short lens (100mm?) and would ideally be stopped down a bit to keep DOF and that alone would help you keep things in focus. Otherwise, there's no way this thing is going to hurl a heavy 7D and lens around following a bird in flight at close distance. It will work fine probably for a bird at distance, but 100mm on APS-C isn't going to do much with a bird at distance.
If you really want to use a Soloshot and track things from a laptop remotely, I think using a dSLR & lens is probably not the way to go.
Very best,
MontanaMike
Joined Mar 2016
Mar 25, 2016 19:22 |  #9
Wow what great feedback. Learned so much today. I realize there are going to be issues to workout and this may very well fail. But I have this vision that if I can get all the elements to work together, the result could be a changer. Guess there's nothing to lose so what the heck.. When and if I decide to pursue this I will post whats happening. Again thanks to all for your help.
Bassat
"I am still in my underwear."
Joined Oct 2015
Mar 25, 2016 19:41 |  #10
I'm pretty sure you CAN'T have BBAF engaged while using remote shooting. Put AF back on the shutter release button.
Snydremark
Gallery: 66 photos
Mar 25, 2016 19:47 |  #11
Bassat wrote in post #17948737 (external link)
This is true, also.
NullMember
Mar 26, 2016 10:32 |  #12
bannedPermanently
MontanaMike wrote in post #17948223 (external link)
So how does "Soloshot" actually follow a bird in flight?
MalVeauX
Joined Feb 2013
Mar 26, 2016 10:33 |  #13
john crossley wrote in post #17949388 (external link)
It doesn't. He wants to attempt to track it manually, remotely, with a joystick.
Very best,
NullMember
Mar 26, 2016 12:16 |  #14
bannedPermanently
MalVeauX wrote in post #17949389 (external link)
Very best,
Crikey, I think I'd just stick the camera on a tripod and look through the viewfinder.
MontanaMike
Joined Mar 2016
Mar 27, 2016 11:11 |  #15
Here is another thought, how about using a mirror less camera and tether it. That way you are not altering the function of the camera. Maybe Canon has something available or Sony but not familiar with Sony products.
4,950 views & 1 like for this thread, 7 members have posted to it.
998 guests, 183 members online
