I'm looking to put together a lighting outfit with two heads, primarily for strobing sports in 'fairly' small indoor venues - but also with some flexibility for location portraits.
I'm currently using a couple of speedlites to do the job... but they don't have quite the power to do the job really well.
My gut reaction tells me to go for a Lumedyne system. Small and portable. I like the idea of having separate battery packs for each head and the flexibility of the Lumedyne modular power packs/batteries. I won't always be able to find mains power points near the lights and I don't like the idea of having trailing mains cables. I'll also be using PWs to fire the flashes in order to keep the cabling H&S issues to a minimum.
The size of the Lumedyne units also seems to be advantageous. The lights/batteries should all fit together in a large gadget bag which will make it easy for me to transport and (fairly) quick to set up at the venues.
If you have experience of using Lumedyne kit, I'd be very keen to hear from you! I've carried out a search of past threads, but didn't find a huge amount of info. My main concern is whether the Lumedyne's recyling times and power will be up to the job. I think that the 400w/s Signature heads should do the business, but I'd be interested to hear any feedback.
I also like the idea that you can add simple diffusers to the front of the Lumedyne heads for rough and ready portraiture, rather than fit a soft box etc... and, yep, I have studied Neil Turners www.dg28.com
site in detail
Another option I'm looking at is the Bowens Esprit Gemini 500w/s 2-Head Travel-Pack kit - http://www.shopcreator.com …Photographic/BW4320/24786
. The downside seems to be that this is a much bulkier unit... but it is certainly a much 'cheaper' alternative. Again, opinions welcomed.
Any other thoughts? Bear in mind that I'm the UK... Lumedyne and Bowens are both available without the need to import.
Thanks in advance.
---- Gavin
