Stefan A wrote in post #17956184
Thanks for the advice. Alveric - so you just list these items on a sheet and ask for a signature? As far as the actual invoice, should anything special be included. I just need a way to request the money and make sure it covers everything that needs to be covered.
Stefan A wrote in post #17956189
Also, I am note sure what I should put for Exclusivity and Media. What are those for?
Take a look at this sample invoice (I just blurred my client's info):
That's what an average invoice looks like, give or take some details. Note that I appended the licence terms below the concepts and pricing, so that it's all in one page (since you're invoicing for only one item, it should definitely fit in one sheet). The big black box is where YOU sign the invoice (you can scan your signature and keep it as an image file for future use).
To avoid myself headaches with extensive micromanagement, I simply use 'Unlimited' for media: this allows the client to use the images on printed materials, as well as web sites, or even video footage.
Exclusivity is another animal, though –one you need to be careful with. In a nutshell, you'd want to use 'Non-Exclusive' as that allows you to continue to use your own photo and/or licence it to other clients/parties. You need to check with the magazine if this will fly with them. If they require certain or full exclusivity, they'll tell you, then you decide whether it's worth it to grant it or not. If you need to grant 'Exclusive' terms then you'd also need to change the
Duration field from 'Perpetual' to a reasonable number of months or years (again, check with the magazine); because if you give someone 'Perpetual & Exclusive' that's not unlike giving them the copyright, essentially. When you grant exclusive rights, nobody else can use/display/licence said image, not even yourself.
If you want a more in-depth explanation, you can refer to this fragment of a publication I was preparing**:
Copyright Matters (Beta document)
______________
**Do note that such publication is intended for client education purposes, and in no way constitutes professional legal advice.
