Hello.
I have four zoom lens' in my collection all of which work admirably.
The odd thing I have noticed is, I almost exclusively use them at the extremes and basically waste the middle bit.
I'm wondering, am I the only one who does this?
fordmondeo I was Soupdragon in a former life. More info | Apr 09, 2016 01:14 | #1 Hello. Vaginator9000
bildeb0rg Goldmember More info | Apr 09, 2016 05:03 | #2 Nope, me too. But when I looked at going all prime the cost was hideous for the same coverage. Damn you L lenses ߘ
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Apr 09, 2016 05:49 | #3 I don't. 24-150, 17-55, 17-40 I'm all over the place. My 100-400 and 70-300 it's more at the extremes. Not sure why, but call me JJ.
JeffreyG "my bits and pieces are all hard" More info | Apr 09, 2016 07:23 | #4 I don't. My tendencies are to use the entire range of whatever zoom I have mounted. I've usually thought about what I will be shooting and from where when I mount the lens, and I select the range accordingly. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Apr 09, 2016 08:04 | #5 JeffreyG wrote in post #17965676 I don't. My tendencies are to use the entire range of whatever zoom I have mounted. I've usually thought about what I will be shooting and from where when I mount the lens, and I select the range accordingly. I guess if you are always shooting at the long end of your zoom (for example) then this is a hint that you have the wrong zoom mounted and should select a longer one. If you are using both ends of the zoom range exclusively.....well, I guess the solution would be to have two bodies and put a wider zoom on one of them and a longer zoom on the other. You're helping me justify more glass. Many thanks. Vaginator9000
PhotosGuy Cream of the Crop, R.I.P. More info | Apr 09, 2016 10:06 | #6 fordmondeo wrote in post #17965540 Hello. I have four zoom lens' in my collection all of which work admirably. The odd thing I have noticed is, I almost exclusively use them at the extremes and basically waste the middle bit. I'm wondering, am I the only one who does this? Before digital, I worked for years mostly with the 20mm & 105mm. Next was the 50mm, & 200mm. I almost never used the 35mm. FrankC - 20D, RAW, Manual everything...
Apr 09, 2016 11:06 | #7 If I run exposure plot on all my images, there are spikes at the focal lengths where all my zooms start and end and well as where I have primes. But I still use all the inbetweens as well. Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
bildeb0rg Goldmember More info | Apr 10, 2016 01:10 | #8 JeffreyG wrote in post #17965676 I don't. My tendencies are to use the entire range of whatever zoom I have mounted. I've usually thought about what I will be shooting and from where when I mount the lens, and I select the range accordingly. I guess if you are always shooting at the long end of your zoom (for example) then this is a hint that you have the wrong zoom mounted and should select a longer one. If you are using both ends of the zoom range exclusively.....well, I guess the solution would be to have two bodies and put a wider zoom on one of them and a longer zoom on the other. Possibly true for a working pro, but not for a weekend warrior like me e.g. fancy dress party or summer ball I don't want to take multiple bodies or lenses so my options are 17-40 or 50L, (not wide enough) my 70-200 being too long. For groups on a table or the dance floor it'll be 17mm all night and couples at 40mm and probably a step back too. This isn't an inability to select the correct lens, its about practicalities.
Apr 10, 2016 09:11 | #9 I haven't checked but I'm guessing that a majority of my shots are at the extremes of my zoom lenses. Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
MatthewK Cream of the Crop More info | Apr 10, 2016 09:26 | #10 I once had the 24-70 and 70-200 zooms (original f/2.8 v1s), and had the same epiphany as you did, so I sold them and purchased primes. A couple of years later, I started to regret it immensely, so reversed course and ended up with the mixture of primes and zooms I have today.
JeffreyG "my bits and pieces are all hard" More info Post edited over 7 years ago by JeffreyG. | Apr 10, 2016 12:20 | #11 MatthewK wrote in post #17966898 I once had the 24-70 and 70-200 zooms (original f/2.8 v1s), and had the same epiphany as you did, so I sold them and purchased primes. A couple of years later, I started to regret it immensely, so reversed course and ended up with the mixture of primes and zooms I have today. Well, even if you were to shoot 100% at the ends of a zoom range and never use the middle at all, every zoom you have would still perform like two different primes for you while mounted. The 24-70 would be both a significant wide angle 24mm lens and a short telephoto 70mm lens. That's already handy as compared to having to pick just one of those two focal lengths. Image hosted by forum (786504) © JeffreyG [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
Apr 10, 2016 12:35 | #12 there's no perfect solution. zooms are limited by range and aperture, primes are limited by range. Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
bildeb0rg Goldmember More info | Apr 10, 2016 14:18 | #13 I was all prime when I had FD lenses, from 20mm to 300mm, so it wouldn't be that much of a culture shock to go back. As I said earlier it's just the huge cost involved to get primes for the same coverage as a set of zooms. I think mathewk has the right idea in that they should be added to compliment each other, especially if it's for a particular use. I'm currently resisting the urge to buy either a 24L or 35L for boxing and martial arts. Of course with 1Dx I could probably use my 17-40 by pushing the iso a couple of stops, but that would be even more expensive. And I'd still want the lens
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Apr 10, 2016 15:00 | #14 FEChariot wrote in post #17965869 If I run exposure plot on all my images, there are spikes at the focal lengths where all my zooms start and end and well as where I have primes. But I still use all the inbetweens as well. JeffreyG wrote in post #17967069 Well, even if you were to shoot 100% at the ends of a zoom range and never use the middle at all, every zoom you have would still perform like two different primes for you while mounted. The 24-70 would be both a significant wide angle 24mm lens and a short telephoto 70mm lens. That's already handy as compared to having to pick just one of those two focal lengths. And for me (and a lot of other people I would guess) a 24-70 actually works as a very wide 24, semi-wide 35, normal 50 and short telephoto 70. I also wonder just how folks are interpreting their data. It's inevitable that any use you might like beyond the ends of your zoom range will pile up there. For this reason almost any histogram of lens usage will show some peaks at the ends. Here below is the histogram of my own use of the 24-105 zoom. I guess some people might look at this as showing that I use the lens heavily at the ends, but my take is that a full 66% of all shots taken with the lens were NOT at the ends, meaning I'm really using the entire range of the zoom. I think that from looking at my own figures this is the real situation for a lot of photographers. You will have a significant spike at each end of a zoom range, or where you have a prime. Another thing that will skew things a bit is being Focal Length limited, either end, but especially at the long end. When you are limited in range you will likely see a bigger than usual spike at that limited FL. Jeffery's plot for the 24-105 shows what I would expect a normal distribution to look like where there are both longer and shorter options with other lenses available.
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Apr 10, 2016 15:58 | #15 There is another way to look at the chart. About 660 images were taken at the fringes and about 1290 taken somewhere in between so your about twice as likely to take an image somewhere in between as at one end or the other. Not sure why, but call me JJ.
| Latest registered member is semonsters 1455 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
