With time to kill, still waiting for the replacement Motherboard ( now in week 5! ).
It seems I have a choice to make.
Previously I set the sytem up as follows
1. PCIe - UEFI ssd To boot from Intel 400GB PCIe 750 SSD to run Win 10 and programs and current shoot to edit.
2. Sata - AHCI to run two Samsung Evo 850s , and I also connected the old laptop's Toshiba 500GB Sata HDD.
It all worked.
The PCIe config is set in stone, as it needs to be Boot: UEFI and set as EFI. - so that is sorted.
When you set up the Sata Contoller there is a choice IDE, AHCI OR RAID ( default AHCI ).
Having now bought one 4TB HGST 7,200 HDD to archive off old stuff, it seemed a cheap option to buy another and copy the archive. And also a secure copy for the safe on USB 3.0 WD 2TB Passport drives.
So I thought OK why not Raid 1 those 2.
I specifically do not want the SSDs mirrored, cant afford that luxury and need the storage.
Looking at the MB it has 4x SATA connectors and a further 4x sSATA connectors.
In the BIOS it looks like you can set up the SATA and sSATA controllers separately. Of course as this is complicated SM have sod all explanation of what is happening.
Weirdly the MB Diagram only shows the SATA connectors? Go figure that. They are described in the manaual and sure as hell are physically there. .?
Q1. Is it true if you set the system up as AHCI you cannot then switch to RAID without either reloading the OS or fiddling in the registry? ( I wont do that - too little knowledge ).
Q2. Does it sound logical that I am correct that I could set the SATA controller as AHCI for the Sammy SSDs and the sSATA controller for RAID 1.?
[I am not sure, as the Block Diagram doesnt show these other 4 sSATA connections or the respective controller]
Q3. If you can set the controllers up seperately (and there are in fact 2?), If I set the sSATA to RAID, Could I attach just one drive to the sSATA connection?.
- My thoughts being, get one of these drives, and see if they are OK i.e. Not too noisy etc. Didnt really want to buy 2 without seeing what they are like.
- Neither do I want to set the first one up as AHCI, and then buy another and have to reinstall the OS again
Q4. Is it true that AHCI is a superset of RAID.? I am assuming if the Bios offers one the chance of setting up RAID it will be using the MBs Raid controller ( on the C612 PCH chipset?) ? i.e. Not relying on me going out and buying a seperate Raid controller card?
BTW I am not overthinking this - really trying to learn and understand my kit
So any explanation advice will be much appreciated.
Hopefully this ground work will avoid uneccessary work and speed up the time to get this dam system operational.
