Thread started 13 Apr 2016 (Wednesday) 18:34
Trying to fix acoustics in my studio
Iamjhil
Joined Jun 2014
Apr 13, 2016 18:34 |  #1
My studio area is great lots of open room tile floors, but it created a horrible echo. I'm not sure what the best solution is to fix it. But I have some styrofoam boards. And was thinking of using them. Putting the, on caster wheels so I can roll the, out around the room when I'm filming..
Would love to hear your input, thoughts, ideas.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/04/2/LQ_787140.jpg
Image hosted by forum (787140) © Iamjhil [SHARE LINK]
gewb
Gallery: 326 photos
Apr 14, 2016 18:26 |  #2
Room dimensions?
Types of surfaces and types of construction?
Regards,
GEWB
90D / 60D / Pro1 / A85
bumpintheroad
Self-inflicted bait
Gallery: 21 photos
Joined Oct 2013
Apr 14, 2016 18:42 |  #3
I don't think rigid styro is going to help any, particularly not with that flat surface. In the (bad) old days ('70's) we used to hang shag carpet remnants on the walls. Often several layers. Now there's convoluted foam panels you can get pretty cheap from Amazon and eBay. Glue them to your styro panels and add wheels if you want them to be mobile.
http://www.amazon.com …/dp/B00ATP5KF6/​ref=sr_1_6 (external link)
-- Mark | Gear | Flickr (external link) | Picasa (external link) | Youtube (external link) | Facebook (external link) | Image editing is okay
bacchanal
Apr 19, 2016 07:22 |  #4
It really depends on the dimensions of the room and the frequency of echo that you're trying to eliminate. I had a square living room that had a terrible reverberating echo, and I managed to mitigate it pretty well by using ceiling tiles (spaced out, covered in thin fabric) on the walls.
Another cheap DIY panel type that I've seen was made of thin plywood or veneer that was bowed out from the wall in a convex shape. The panels were held in place by wood slats on either side. This works as an inexpensive diffusion panel and could work really well when combined with something like ceiling tiles. You could alternate panels to get the desired result. But it's really all about room dimensions and placement.
1000arms
Jun 19, 2016 13:51 |  #5
You might look at http://www.auralex.com …ld_Acoustics_11​-14-13.pdf (external link)
J ­ Michael
Jun 28, 2016 06:42 |  #6
Look here https://www.gearslutz.​com …tudio-building-acoustics/ (external link) and particularly the acoustic panel sub-forum. There is a guy who frequents that forum and sells panels at a very reasonable cost, competitive with building your own rock wool panels.
3,513 views & 1 like for this thread, 6 members have posted to it and it is followed by 2 members.
1526 guests, 130 members online
