FORUMS General Gear Talk Camera Vs. Camera
Thread started 15 Apr 2016 (Friday) 05:56
Camera recomendations for a friend?
urbanfreestyle
I am a squirrel who loves rubbing bottles and I have Nuts in my drawers, too!
Joined Dec 2013
Post edited over 7 years ago by urbanfreestyle.
Apr 15, 2016 05:56 |  #1
He is working as an agent for a private investigations firm.
He needs the camera for surveillance operations which could range from sitting in his car to serious covert rural surveillance which is why it needs to be rugged or cheap!
His bridge camera is ok but the lens extending when im zooming is a dead giveaway and trying to autofocus on a distant target is a nightmare.
Requirements:
Ideally weathersealed
Cheap ish
Good zoom (ideally one that doesnt extend)
Good burst mode
Maual focus
Optical veiwfinder that can be used with the lcd screen off
The ability to shoot high quality video as well.
I've told him it's going to be hard to get a setup cheap that will suit all of this. Possibly a Canon 7D and a 70-200?
Facebook (external link)
Canon 1D Mk IV | Canon 50mm 1.8 Mk1 | Sigma 'Bigma' 50-500 | Fuji XE1 | Helios 44/m | 50mm 1.4 | Manfrotto 055CX PRO3 | 3LT Mohawk ballhead | Lubitel 2 med format camera |
Bassat
"I am still in my underwear."
Joined Oct 2015
Apr 15, 2016 06:01 |  #2
Panasonic DMC-FZ???. They have big zooms, OVF, and excellent fast Leica glass. Stealth with 7D/70-200 2.8? Methinks not.
urbanfreestyle
Joined Dec 2013
Apr 15, 2016 06:04 as a reply to  @ Bassat's post |  #3
Yeah, im just thinking that is very similar to what he has in a bridge camera
BigAl007
Gallery: 556 photos
Apr 17, 2016 06:53 |  #4
The problem is always going to be the lens extending for optical reach. Either you have to have a permanently extended lens to accommodate the required focal length, or it will have to extend when used at the longer focal lengths. To me it sounds like a bridge camera is going to be the best compromise, and it will always have to be a compromise. One advantage of the bridge cameras is the relatively small sensor size, with it's high "crop factor". A good superzoom bridge camera with an approximately 5 to 6 times crop factor is going to give you the same sort of field of view as a 400mm on APS-C or 600mm on 35mm, but with a physical 100mm lens focal length.
I have a Sigma 28-300 lens which for the focal length is quite compact. even so it still extends to be about 12" long at 300mm, although at 28mm it is about the same size as a normal range APS-C sized zoom (a little fatter than my 18-55 but about the same length). The Tamron 16-300 is about the same size, both at the wide and long ends. So you could use one of those on an SL1/100D, for a discrete ish camera lens combination with an APS-C sized sensor, but it is till going to be quite noticeable at the long end of the zoom. The bridge type camera will likely be smaller than this as it is only having to go to a physical 100mm or so FL.
I cannot think of anything else that will give him the long reach that he will want. Anything over 300mm on APS-C is going to be big and noticeable, and getting to a physical 600mm FL is going to give you a lens that is 5" plus in diameter and three feet long.
Unfortunately the physics constrains the size that the lens has to be. Fancy glass can help a bit to reduce the size of a lens, but it is still the physics that limits the size.
Alan
m.eo.w
Joined Sep 2015
Apr 17, 2016 17:49 |  #5
sl1/7d + 200L prime + 2x tc
a77 + 500 f8 mirror
Canon 1Dx - Sigma 120-300 2.8
Canon 5DII - Canon 24-70 L 2.8
Canon 7D - Canon 40STM 2.8
Canon FT - 55 1.2
1,785 views & 1 like for this thread, 4 members have posted to it.
1509 guests, 131 members online
