Nascar Nut wrote in post #17973613
So the reason I posted this is, when you set the shutter button half press to metering and AF start that it won't mess with my AF-ON button that is set to metering and AF start AI servo. So now when I push and hold the AF-ON button and track my moving subject and now push the shutter button to take the photo while still holding the AF-ON button, does the shutter button try to focus before taking the shot? Hope that made sense.
Think of it this way. The shutter button is, by default, acting as two, distinct buttons. Button 1 is "Metering and AF Start" for a half press (this is the function you can remap) AND shutter release, which you cannot change. So, when you set "Metering and AF Start" on any button, it is doing the exact same thing as a half-press of the shutter button; which is engaging whichever AF function you have set on the camera. So, you *can* have both buttons set to "Metering and AF Start" and if you are using one (say the AF-ON button) and then engage the other one, the camera knows it's already trying to focus and doesn't "try again".
HOWEVER, The buttons cannot be set to control separate AF functions. Both buttons will still be triggering AI Servo if that is the AF mode you currently have selected; so this, "set the AF-ON button to us AIServo to follow my subject and snap my shot with the shutter button and then have single shot work as normal by pressing the shutter button half way to compose and then press all the way to take the shot", is not possible.
To get around that, when you think you're going to be in situations where you want to hand your camera to a non-photographer, you can:
A. Set the camera to 'P' mode and have them take the snapshot
B. Define a custom setting (C1, C2, C3) with the AF setting active that you want [In this case, One Shot AF); this one would also require that you evaluate where you are and lock in your metering, too. Otherwise, this would be a lot of work to achieve A, above.
C. Map another button, like the DoF preview button to toggle One Shot/Servo when pressed; leave the camera set to One Shot AF and then hold that while you're doing your own shooting. That way, when someone else picks up the camerra, it will function in One Shot. I say the DoF preview button simply because, on the 7D!!, they moved it to a location that is pretty easy to access/use, finally. It's quite easy to reach with your ring finger when holding the camera normally.
Does that (wall '0 text) help?
