Thread started 25 Apr 2016 (Monday) 11:17
Wrinkles in Vinyl Backdrop Dilemma
chexjc
Joined Sep 2014
Post edited over 7 years ago by chexjc.
Apr 25, 2016 11:17 |  #1
Hi all,
I'm photographing dogs in front of a blue vinyl backdrop and having a hard time separating the background enough to hide the ripples in my backdrop.
Here's a picture of my setup:
IMAGE: http://imgur.com/pAtmKIR.jpg
I'm going to be using this setup next month at a pet festival as a "dog photo booth." I kind of understand the logistics of my situation, but I'm not sure if there's a convenient way to avoid this given the circumstances. I have a 4x4' backdrop and I'm shooting the dogs with my 17-40L because I want some of that hilarious distortion.
I expose the camera for the ambient/shadows and light the dog with a soft box. I've also used a speelite to light the background, which seems to help my problem. The problem I'm having is that I need a small enough aperture to get the whole dog in focus (which is tough when I'm so close to them) without having the ripples in the backdrop stand out so much. What am I doing wrong here? I'm guesing the answer is to physically separate the dog and background more, but I can't because of how small it is and the lens that I want to use.
I've had good results in photoshop by painting over the backdrop with a slightly transparent matching color, but I don't want to have to do this for the hundreds of dog photos I'm anticipating I'll take. Is there a good way to get the ripples to smooth out? Here are some examples after being corrected:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/04/4/LQ_789480.jpg
Image hosted by forum (789480) © chexjc [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/04/4/LQ_789481.jpg
Image hosted by forum (789481) © chexjc [SHARE LINK]
Canon 6D x2 | 17-40L | Sigma 35 ART | 50mm f1.8 STM | 85mm f1.8 | 135L
Website (external link) | Instagram (external link) | flickr (external link)
Wilt
Post edited over 7 years ago by Wilt.
Apr 25, 2016 12:01 |  #2
SEPARATION is the key to making wrinkles less obvious...as well as longer FL and larger aperture.
But shooting with 17-40mm FL inherently adds to your problem!
Look at the amount of blur at 17mm vs. at 40mm, when the background is only 1m behind subject.
But look at how the blur intensity increases if you simply go to 80mm FL at f/2, with background 2 m behind subject.
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/blur2_zps8hfz8huv.jpg
Yes, you sacrifice your desired perspective distortion, but it helps solve your issue of background wrinkles.
bigVinnie
Apr 25, 2016 12:43 |  #3
I gave up on cheap background material for photbooths.
These guys: http://backdropoutlet.​com/ (external link) Will do anything you need. I order the Titanium cloth which is a fleece like material with grommets. It's expensive but no wrinkles and the grommets let me tie it to my stands.
This is a pretty crappy picture but you can see backdrop. The bottom is not tied off.
This one is 8'x8' and was about $180. It will probably outlast the rest of the gear.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/04/4/LQ_789486.jpg
Image hosted by forum (789486) © bigVinnie [SHARE LINK]
Act1 Photo Booths (external link)
MalVeauX
"Looks rough and well used"
Gallery: 2135 photos
Joined Feb 2013
Apr 25, 2016 12:45 |  #4
Heya,
Distance between subject and background, so that the background is well outside of your depth of field, is one immediate way.
Very best,
SkipD
Joined Dec 2002
Apr 25, 2016 14:19 |  #5
In addition to doing what is suggested above, I'd guess that a good hair dryer could help soften the material so the wrinkles would be pulled out be the weight on the bottom. Add weight to the bottom bar if need be.
Cross lighting enhances the wrinkles. Lighting that is directly on the background and in line with the camera's centerline hides a lot of wrinkles in my muslin backgrounds. I usually do that with a light right behind my human portrait subjects. This could be tricky with animals, of course.
Skip Douglas
ksbal
Gallery: 374 photos
Best ofs: 9
Apr 27, 2016 13:18 |  #6
bigger background, more distance. if you want to use the wide angle, then a 10ft bg (wide) isn't out of the question, and you can do 5 foot wide polyester fabric, and get 3 yards of it, use A clamps on the material along the frame, and should be in pretty good shape. If you get slightly stretchy polyester fabric, you can pull the wrinkles out of it with the clamps.
Here is a good example, 57" wide, blue fabric (external link)
Godox/Flashpoint r2 system, plus some canon stuff.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Apr 27, 2016 14:22 |  #7
do you store your backdrops horizontal/flat on the ground? if so, don't, stand them up.
also try rolling it up the other way and letting it sit for a while, it should be enough to get rid of the waviness going the other direction.
wcameron
Location: Canmore, AB, Canada - The Heart of the Rockies
May 06, 2016 01:31 |  #8
Don't forget that a shorter focal length includes MORE background due to the angle of coverage. Move back a bit and you will have less depth of field AND less of the background so a lower likelihood of the wrinkles showing up in your image...not to mention less distortion in the faces of the dogs you photograph. Since that is what you're going for, use a larger background so you can increase the separation between the dog and the background. I use the same lens and wish they made it in a 1.8 version for even lower depth.
Ward
http://Facebook.com/Wa​rdCameronPhotography (external link)
Canon EOS 5Ds, Canon EOS 6D, Rebel XTi, Sony RX100, GoPro Hero 6, Sony A6000, Sony RX100 viii
redrocket
Gallery: 15 photos
May 29, 2016 10:00 |  #9
http://petapixel.com …roducing-pet-photo-booth/ (external link)
Congratulations on your sucessful project.....
I have G.A.S.
4,996 views & 1 like for this thread, 9 members have posted to it and it is followed by 3 members.
1505 guests, 131 members online
