mcoren wrote in post #17992386
Are you saying that the camera compensates by increasing or decreasing the exposure time slightly? Is that even desirable on a pro lens? While that would make the EV the same, it could be noticeable in terms of DOF. Since the camera displays aperture in 1/3 stop increments (at least, the enthusiast 70D that I am familiar with), doing it that way means the displayed aperture might be off by as much as 1/6 stop. I don't know how noticeable that would be for people who want precise DOF control. I'm pretty much an "f/8 and be there" kind of guy personally.
Mike
No but since we are now using electronically controlled apertures the control system is able to vary the size of the aperture, so that is you set it to any value that is equal to or smaller than the maximum aperture at the longest zoom setting the f/number remains correct. This is possible with an electronic aperture diaphragm, but on old lenses with a manually controlled aperture diaphragm the control ring has predefined click stops at fixed diaphragm diameters, that are marked with the f/number that applies at the shortest (usually) focal length. Even for lenses that have auto stop down systems, it is still the clickstop control ring that sets the diameter that the aperture will be.
Constant aperture zoom lenses work differently, and the lens construction is more complex, hence why they are usually more expensive. In a constant aperture lens the zooming system is designed so that the physical aperture is placed in front of the zoom mechanism. This means that as you zoom the lens in and out, you also zoom the image of the aperture. If as far as the film/sensor side of the lens system is concerned it sees the size of the aperture change it causes the f/number to change. Because the focal length also changes, the two cancel each other out, and the ratio between the focal length and the aperture diaphragm diameter remains constant, and so does the f/number. This works just as well for manually controlled apertures as it does for electronically controlled ones.
Alan
