A few spec to consider:
Lexar 1000x 32GB is a UHS-II card. Sandisk Extreme Pro 32GB is a UHS-I card. USH-I has interface speed limit of 104MB/s. USH-II is in ~300 range. So if you also have a UHS-II card reader, Lexar 1000x will read faster than Sandisk Exteme Pro via card reader.
In terms of write speed, Sandisk has edge. Write speed is limited by the flash, not the interface. Lexar spec says 75MB/s. Sandisk is 90MB/s. You can only see this in card reader tho.
Inside 5D3, all these speed means nothing because 5D3 has SD interface limit of 25MB/s.
In term of reliability, Sandisk should have edge here because 32GB Extreme Pro uses SLC flash to achieve the 90MB/s write. Lexar's 1000x's 75MB/s can be achieved by MLC flash. When possible, flash manufacture will also use MLC because it is 1/2 the cost. SLC reliability >> MLC reliability from NAND flash point of view.
