Thread started 02 May 2016 (Monday) 07:38
Any recommendations for aftermarket LP-E4
Bassat
"I am still in my underwear."
Joined Oct 2015
Post edited over 7 years ago by Bassat.
May 02, 2016 07:38 |  #1
I recently purchased a 1DIII. The battery is original Canon and show 3 green bars of recharge performance. It goes down to under 20% with 1100 frames and a lot of chimping. That is kind of borderline to getting through a heavy day of a 6 year old's games and such.
I checked Amazon.com and found DSTE and Wasabi. Both have enough bad reviews to scare me a bit. The LP-E4n is $180 and the LP-E4 is $110. I searched here on POTN, but everything is over 2 years old. Can anyone recommend Wasabi or DSTE? I use Wasabi LP-E6 in my 6D with no problems.
Phoenixkh
a mere speck
Gallery: 67 photos
Joined May 2011
May 02, 2016 08:31 |  #2
Bassat wrote in post #17992810 (external link)
I had a problem with the Wasabi LP-E4. It overheated and would shut down the charger after about a 60% charge. I ended up biting the bullet and getting the Canon LP-E4n. It hurt for a few minutes.... then I didn't even think about it again. Well, until just now. ;)
Kim (the male variety) Canon 1DX2 | 1D IV | 16-35 f/4 IS | 24-105 f/4 IS | 100L IS macro | 70-200mm f/2.8L IS II | 100-400Lii | 50 f/1.8 STM | Canon 1.4X III
RRS tripod and monopod | 580EXII | Cinch 1 & Loop 3 Special Edition | Editing Encouraged
Bassat
Joined Oct 2015
May 02, 2016 08:41 as a reply to  @ Phoenixkh's post |  #3
Thanks, Kim. Does the new LP-e4N work fully with the old 1DIII?
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed.
May 02, 2016 08:44 |  #4
The new LP-E4N is rated at 2450 mAh, vs. 2300 mAh for the LP-E4 pack. In spite of this difference, it remains compatible with the EOS-1D Mark III, Mark IV, and the EOS-1Ds Mark III (as explained below) - (from Canon directly)
Bassat
Joined Oct 2015
May 02, 2016 08:47 as a reply to  @ TeamSpeed's post |  #5
Thanks for the info. I guess I'll go shopping. $164 for a battery seems pretty steep, though!
Bassat
Joined Oct 2015
May 02, 2016 08:59 |  #6
OK, Adorama & BH both have the LP-E4N for $164. It occurs to me to ask the question: Does the E4N battery charge OK in the original 1DIII charger? Or do I also have to buy an (N) charger?
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
May 02, 2016 09:23 |  #7
The answers can be found here: https://learn.usa.cano​n.com …lp-e4n_battery_pack.htmlp (external link)
Bassat
Joined Oct 2015
May 02, 2016 09:32 as a reply to  @ TeamSpeed's post |  #8
Interesting. The new battery is compatible with the old charger, almost. If the $164 battery isn't going to be fully charged on the old charger (after a while), why bothers. Seems a $29 battery that charges to 60% is about the same thing, for $135 less. Back to confused.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed. (5 edits in all)
May 02, 2016 09:45 as a reply to  @ Bassat's post |  #9
If you have future plans on going to the newer 1D series that can make better use of the LP-E4n, I would get that. Otherwise, I agree, just buy a couple of the aftermarkets and use them until they don't work any longer. That should get you through about 1-2 years, based on my history with aftermarket LP batteries, with my 1D4 and 1D3.
That compatibility was more to not upset the current 1D ownership base when Canon decided to introduce the new battery and 1DX, so that owners could still interchange the usage. I personally would rather have 1 or 2 aftermarket backup batteries at $60 or less, and worry about LP-E4N later if I upgrade bodies.
This seller has 1 negative feedback for the entire year, and seems to be selling OE batteries for pretty decent prices.
http://www.ebay.com …0ff86d:g:WVkAAO​SwT6pVrQRc (external link)
Maybe that is a good compromise? I would do more research to verify though.
Bassat
Joined Oct 2015
May 02, 2016 10:11 as a reply to  @ TeamSpeed's post |  #10
I may be upgrading to a 1DIV. I want to get through a few shoots with the 1DIII first, and see how it goes. The upgrade in crop-ability is the appeal. However, I don't believe I am focal-length challenged. I have a lot of choices for sports/athletic glass: 85 1.8, 135L, 70-200 f/4L IS, 100-400L, 1.4x TC. I've worked a few ISO 3200 files from the 1DIII. It is adequate for a grandpa shooting little kids.
Anyway, the 1DIV is made for the LP-E4, not the N-version. No way I can afford a 1DX (or II).
Phoenixkh
a mere speck
Gallery: 67 photos
Joined May 2011
May 02, 2016 14:09 |  #11
Bassat wrote in post #17992946 (external link)
The new LP-E4n charges fully in my 1DIV charger.. not sure about the 1DIII charger. I'm not anti third party batteries. I have used Sterlingtek for all my previous camera bodies and they worked better than the OEM Canon batteries. I'm all for less expensive when it makes sense. That being said, what makes sense to me might not make any sense to anyone else. ;)
Bassat
Joined Oct 2015
May 03, 2016 23:12 |  #12
I ordered a DTSE LP-E4 from Amazon. Most folks like it. Some had real problems. For $26, I'll give it a try. If it doesn't work, I'll get the Canon flavor.
BigAl007
Gallery: 556 photos
May 04, 2016 16:04 |  #13
Bassat wrote in post #17995203 (external link)
Well since it's from Amazon, you at least have their rather generous returns policy to fall back on.
Alan
Bassat
Joined Oct 2015
May 04, 2016 16:11 |  #14
BigAl007 wrote in post #17995933 (external link)
Alan
Yes. Counting on it.
Bassat
Joined Oct 2015
May 15, 2016 06:46 |  #15
An update, of sorts. I got the DSTE battery yesterday. It fits tightly in the camera. If the battery overheats/swells, I'll have to pry it out. The locking mechanism is considerably more flimsy than OEM. It seems frail and will need to be babied along. I shot with it for about an hour with no overheating or such issues. It reads (status/condition) fine. I am suspicious of the 4400 mAh rating. That suggests ~4000 photos on a charge. We'll see. For $30, compared to $165, so far, good enough.
Other Amazon users/purchasers said as much. One said, "Good battery, while it lasts. Use it first, keep your Canon's as backups." Seems reasonable.
4,489 views & 1 like for this thread, 4 members have posted to it and it is followed by 3 members.
1163 guests, 123 members online
