I have come upon a Nikon 50mm 1.4D at a very nice price. Have a bit of a problem however, and hope for some useful advice.
A Quantaray DMC-1A filter is installed and I cannot get it to move. Any experience on how to get it of?
trailguy Senior Member More info | May 04, 2016 13:04 | #1 I have come upon a Nikon 50mm 1.4D at a very nice price. Have a bit of a problem however, and hope for some useful advice.
gjl711 "spouting off stupid things" 57,716 posts Likes: 4035 Joined Aug 2006 Location: Deep in the heart of Texas More info | May 04, 2016 13:07 | #2 A filter wrench, a rubber back, rubber gloves, anything to get a better grip. However, I have found that most times when filters are stuck it's because the filter has cross threaded. An easy way to remedy this is very carefully inspect the joint between filter and lens. If at one spot it seems that the gap is ever so slightly closer than the rest, gently using a knife edge, pry the two until you either hear or feel the filter jump back in the right thread. It's subtle but I have had great success using the technique. Not sure why, but call me JJ.
Snydremark my very own Lightrules moment More info | May 04, 2016 13:08 | #3 There are several "diy" solutions, but you basically need a filter wrench: http://www.amazon.com …keywords=uv+filter+wrench - Eric S.: My Birds/Wildlife
PhotosGuy Cream of the Crop, R.I.P. More info | May 04, 2016 13:09 | #4 FrankC - 20D, RAW, Manual everything...
Sibil Cream of the Crop 10,415 posts Likes: 54444 Joined Jan 2009 Location: SoCal More info | May 05, 2016 07:00 | #5 Snydremark wrote in post #17995768 There are several "diy" solutions, but you basically need a filter wrench: http://www.amazon.com …keywords=uv+filter+wrench Interesting. I never knew there was such a thing.
neacail Goldmember More info | May 05, 2016 07:06 | #6 I use silicone bakeware to remove stuck filters. I hold the bakeware (usually a cookie sheet, but sometimes a silicone oven mitt) flat against the filter, and using only downwards pressure, turn counter clockwise. I also learned a new trick recently . . . using the sole of my shoe! Press the filter into the sole of the shoe, and twist. Shelley
| Latest registered member is Niagara Wedding Photographer 1251 guests, 148 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
