Thread started 09 May 2016 (Monday) 12:45
Can I use the G-Tech G Drive USB on a PC with Windows 10?
Submariner
Joined May 2012
May 09, 2016 12:45 |  #1
This drive looks ideal for me as an external back up drive, so I Will have an archive drive in the pc, and an external one to put in the safe:-
http://www.g-technology.com/product​s/g-drive-usb (external link)
7,200 rpm, external power supply, USB3.0, and hopefully the rumour it uses the HGST NAS drive inside is true , and will match my internal HGST archive drive which is the 7,200 rpm 4TB HGST NAS drive.
My concerns are:-
1. It really seems geared for MAC users, and only talks about support for Windows 7, 8, and 8.1 - will it work GPT NTFS format with Windows 10?
2. Will I need a new driver, or will there be one in Windows 10?
3. Does anyone know if it does use the HGST 7,200 rpm drive inside?
4. Some external drives have some kind of soldered on controller - and if that fails you are stuffed. Ideally I would like it, if all fails, that I Can canibalise this toy, and connect a sata power and data cable and mount it in the PC. Does anyone know how this is built?
5. G-Tech do have a section on converting it to Windows (albeit Windows 8.1). I Right that all this is, is a basic hard drive, and therefore can easIly be reformatted? Or will there be complex power management stuff for the external power supply. ?
I have been burnt twice with cheap external USB drives; that should use the external power supply - but in reality blue screen, after overloading the 0.9amp USB3.0 ports power supply!
6. Has anyone here used this drive and if somwas it with Windows
7. Any views on G Tech G Drive quality.
Hope its a good one as it looks well built (albeit from the pictures) and ticks all the boxes .... If it works ... And works with Windows 10 and is relieable.
Any help advice or other recommendations welcome
But it seem great value at £148. I paid £122 for just the raw HGST 4TB 7,200 NAS drive.
Would there be a market in the UK for my WD Passports 3x 1TB and 2x 2TB. Only used to back up my stuff and then left. So not a lot of disc thrashing?
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
neacail
Gallery: 43 photos
Joined Dec 2013
May 09, 2016 12:58 |  #2
I don't have that one. I have this one: http://www.g-technology.com/product​s/g-drive (external link)
I can't answer any of your questions, but I can tell you that the one I have is not quiet. It is noisy when it is spinning. It isn't really loud, but it is noticeable and annoying: especially at night when my Time Machine backups are running. It isn't suffering from the Click of Death . . . it just audibly whirs, and it has since day one.
Shelley
Image Editing Okay
BigAl007
Gallery: 556 photos
May 09, 2016 20:32 |  #3
As long as you are using the provided power supply it should work fine. I would not expect the power pin to be connected on the USB bus internally within the enclosure. USB memory devices are pretty ubiquitous these days so I would just expect it to work. Since it comes preformatted for the Mac, then yes you would need to format it using NTFS if you want to use it on Windows. I don't think there are any significant differences between formatting the drive for any of the Win versions. Actually the last time I formatted a drive on Win 7 the dialogue window looked pretty much identical to the one that you got when doing the same on Win 3.11. Sometimes I think you really overthink a lot of this stuff.
Alan
John ­ from ­ PA
Joined May 2003
Post edited over 7 years ago by John from PA. (2 edits in all)
May 10, 2016 15:38 |  #4
The datasheet is here...http://support.g-technology.com …B__Datasheet_08​14_web.pdf (external link) and unfortunately it doesn't list Windows 10. The "mobile" does so I would give the vendor a call or email. Websites are often not up to date.
"Mobile" datasheet is at http://support.g-technology.com …tasheet_r4_EN_0​116_LR.pdf (external link)
110yd
Joined Jan 2005
May 10, 2016 22:53 as a reply to  @ John from PA's post |  #5
I have not ventured away from WD for the last few years. I would tend to stick with what
works well in your application, so here is a list of hard drives and failure analysis data from multiple manufactures.
https://www.backblaze.​com …rive-reliability-q3-2015/ (external link)
Hope this helps,
110yd
tim
Light Bringer
May 11, 2016 01:31 |  #6
USB is universal. If it's aimed at Mac you may need to reformat. Just buy a Western Digital, Seagate, or HGST drive - HGST are very reliable.
All hard drives fail. Test your backups regularly, and have more than one copy of all data.
Submariner
Joined May 2012
May 11, 2016 04:16 |  #7
neacail wrote in post #18001219 (external link)
Thanks, yours is the same as my proposed one - only mine has only got USB.
Extremely usefUl hearing about the noise.
I have heard they use th HGST drive inside. I just bought one, well the NAS version , so will see if that makes a noise.
My backups to this will be infrequent - so noise aint too critical but personally quiet machines are generally happy machines so useful to know.
Submariner
Joined May 2012
May 11, 2016 04:25 |  #8
BigAl007 wrote in post #18001751 (external link)
Alan
Thanks Alan
Yeah you are correct I do overthink things, well regarding my first build the 3rd replacement motherboard came and despite a personal commitment from the UKs MD , that it would have the latest Bios, and the very problematic latest ME Firmware ( basically upgrading that caused the system to crash every 3 minutes ) .
Guess what it had the latest Bios but not the latest ME Firmware ..... WTF
So 3 months later the issue is back where it started.
So please forgive my Overthinking.
So where I was worried my lack of skill would prevent me building it. The only issues I have had is getting working components!
Even my heath robinson design has worked brilliantly - very quiet fans at 320 to 390 rpm and individual core temps at 29C to 33C, even stressing it. So way under the max cpu temp. And when it runs it runs like lightening.
Submariner
Joined May 2012
May 11, 2016 04:27 |  #9
John from PA wrote in post #18002663 (external link)
Hi
Thanks, just phone GTech, straight through competent operator, confirmed Windows 10 is fine and they do have HGST drives inside ߙ
Submariner
Joined May 2012
May 11, 2016 04:33 |  #10
110yd wrote in post #18003106 (external link)
Hope this helps,
110yd
Interesting read ... Glad I got HGST 4TB looks like the best.
That said any drive can fail any time eh :) and
Submariner
Joined May 2012
May 11, 2016 04:35 |  #11
tim wrote in post #18003222 (external link)
Thanks Tim, yep I went with HGST 4TB for the online archive drive.
Just pondering wether to get another and back up and disconnect or to go the GDrive route. Only advantage of that is I can put it in the safe.
But hell this workstation weighs a Ton - not to easy to steal. That said ..... In the safe is safer.
Bleufire
Post edited over 7 years ago by Bleufire.
May 11, 2016 11:22 |  #12
Submariner wrote in post #18003298 (external link)
Flood, fire, earthquake, tornado, bad case of mold, etc... Stealing is not the only thing to consider. Having an online copy means that it is an offsite backup. I have like 3xHDD (2 internal and 1 external) which means nothing if a flood, fire or tornado hits my home. Even in my safe, water and fire could destroy it. I keep telling myself if I don't pay for a "cloud" backup, i need to just get a copy onto a HDD and send it with my mom to another state when she visits (TX -> CA), so that way i have 2015 and before all saved if something goes bad at my house.
Just additional food for thought.
5D*Sigma 50/1.4*EF 17-40/4
New to Photography? ----> ENJOY! Canon DSLR! (external link)
tim
Light Bringer
May 11, 2016 15:02 |  #13
I don't really believe there's such a thing as a fireproof safe, or a computer that a thief can't steal.
neacail
Gallery: 43 photos
Joined Dec 2013
May 11, 2016 15:26 |  #14
tim wrote in post #18003822 (external link)
I don't really believe there's such a thing as a fireproof safe)
Nope. There isn't. I had consulted with a fireman friend of mine about them when I was trying to figure out how best to store my ammunition. Specifically, I was concerned about minimizing the risk to firefighters and rescue personnel in the event we had a bad house fire and my ammo exploded on them (interestingly, he said that kitchens are the scariest place to be in a hot fire, as canned goods explode and shrapnel files all over the place).
There are apparently two things to consider with a safe: how long the safe can withstanding being directly in fire, and how long it takes for the ambient temperature inside the safe to rise. The ambient temperature inside the safe can raise to really high levels without the safe being directly in the fire.
In the end I just bought cheap safes that could withstand about a 1/2 hour in the flames and an hour or so before they got crazy hot inside (not in direct flame). To invest a huge amount in safes didn't make much sense to, as I figure if we have a fire that bad we'll have much more pressing things to worry about than documents, ammunition, and hard drives. And, when it comes to photo storage, online storage has gotten pretty cheap. I don't even store hard drives off site anymore.
Shelley
Image Editing Okay
Submariner
Joined May 2012
May 11, 2016 15:44 |  #15
Bleufire wrote in post #18003649 (external link)
Very good points.
In the safe at least I would get up to £40K ref theft.. And its too high for water damage, but fire is fire.
I hear the download to the cloud is a pain.
Yemleaving an HDD at a relatives is probably the way I will go.
4,964 views & 3 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1277 guests, 136 members online
