FORUMS Photo Sharing & Visual Enjoyment Sports
Thread started 12 May 2016 (Thursday) 22:15
Girls Volleyball
MacGrad
May 12, 2016 22:15 |  #1
Looking for any comments or criticisms on these photos -- there's only one more tournament for my daughter this season, so I'm looking for a different style of photo than the typical "Player A attacking / setting / blocking". Anyone have any tips or suggestions for "different" volleyball pics? Limiting factors will be that there's no opportunity to go above the court -- I'm stuck at court level, but I've got a bit of flexibility to move around the court.
7D... Tamron 17-50mm... Canon 50mm f1.8... Canon 100mm f2.0... Canon 70-200mm f4
Zivnuska
Gallery: 72 photos
May 13, 2016 09:14 |  #2
MacGrad wrote in post #18005239 (external link)
If you can't go high, go low. Sit down on court level and get the camera as low as possible.
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i137.photobucke​t.com …ivnuska/2016/ZI​VN8795.jpg (external link)
You should get this picture of the serve. It is easy to focus, you have some choice of background (high v low and crowd v flag or scoreboard on wall). Plus, the arms and ball frame the face beautifully.
http://i137.photobucke​t.com …ivnuska/2016/ZI​VN4339.jpg (external link)
You can even shoot up toward the players:
http://i137.photobucke​t.com …/ZIVN6757_zpsf6​b9496b.jpg (external link)
http://i137.photobucke​t.com …vnuska/Labarb11​11of14.jpg (external link)
Try some shots toward the net:
http://i137.photobucke​t.com …ivnuska/2013/ZI​VN7067.jpg (external link)
http://i137.photobucke​t.com …/2011/PZIV7037-Edit-1.jpg (external link)
Try shooting underneath the net to the other side:
http://i137.photobucke​t.com …ivnuska/2016/ZI​VN8509.jpg (external link)
Don't forget the "Jube" shots.
http://i137.photobucke​t.com …56-Edit-2_zps1da497f5.jpg (external link)
I hope this gives you some ideas.
Phil
www.zivnuska.zenfolio.​com/blog (external link) = My Blog
www.zivnuska.zenfolio.​com (external link)
"It's not tight until you see the color of the irides."
PhotosGuy
Joined Feb 2004
May 13, 2016 10:44 |  #3
Shoot wide:
IMAGE: http://img.photobucket.com/albums/v218/PhotosGuy/Forum%20Junk/_MG_0093.jpg?t=1192828201
Through the net:
IMAGE: http://img.photobucket.com/albums/v218/PhotosGuy/Forum%20Junk/_MG_0224.jpg?t=1192828266
Don't forget the coach:
IMAGE: http://img.photobucket.com/albums/v218/PhotosGuy/SLHS%20Almost%20shots/_MG_0843.jpg
From the stands:
IMAGE: http://img.photobucket.com/albums/v218/PhotosGuy/SLHS%20Volleyball/SLHS_VBall_9-29-12_4949.jpg
Be ready when they win!
IMAGE: http://img.photobucket.com/albums/v218/PhotosGuy/SLHS%20Volleyball/St.L_Vball-Finals_9-23-11_4503.jpg
And finally, how do you salvage a shoot when most of your results from shooting in "Available darkness" look crappy? My solution was to make a poster where small images will look good. :D
Go Ye forth & come back with better results!
IMAGE: http://img.photobucket.com/albums/v218/PhotosGuy/Forum%20Junk/8X-Poster_01.jpg?t=1192828615
IMAGE: http://img.photobucket.com/albums/v218/PhotosGuy/SLHS%20Volleyball/12X_Blackshirts-Poster_2012_01.jpg
Another poster.
JetShooter
Joined Apr 2014
May 15, 2016 19:13 as a reply to  @ PhotosGuy's post |  #4
No suggestions but I think you did a fine job capturing the action and emotion.
MacGrad
May 15, 2016 21:09 |  #5
Thanks everyone... it's my goal to shoot volleyball like Ziv and PhotosGuy, so thankfully my daughter has a few more years left for me to practice!
And PhotosGuy -- that poster is a great idea! Now I'm going to have to go back through my files to see if there are any that looked good at a smaller size that I had originally written off.
Keltab
Post edited over 4 years ago by Keltab.
May 16, 2016 19:50 as a reply to  @ MacGrad's post |  #6
What position does she play? There are a few things each position does that are a little different. For example, setters many times will call plays or approaches with hand signals behind her back or next to her leg as the other team prepares to serve. Outside hitters tend to swing wide of the post, then approach at a strong angle - can you capture that angle so you she what she does? Blockers (especially middles) tend to have a step pattern to get to the outside to close a block. Their explosive last step could be a great capture.
I'm a coach who is learning the photo side. At least that's my excuse! I have coached everything from 6th graders to NCAA... each player develops habits and cues as to what she will do and how she will attack a play. Capturing that is what I am learning now. My favorite was a middle blocker who stuck her tongue out whenever it was a quick hit - hers or the opponents. She didn't believe me until I captured it in a photo. She still does it - but tends to smile a little afterwards!
Your images are good, and with a few more years, I look forward to seeing what you can capture moving forward.
And the guys in this thread are great ones to aspire to shoot like - especially Ziv - I have enjoyed his work on POTN for quite a while!
Thanks for sharing!
The Only Difference Between Ordinary and Extraordinary Is That Little Extra :D
MacGrad
May 18, 2016 21:15 as a reply to  @ Keltab's post |  #7
She's a middle so, at the venues she's playing in right now, I have to battle the net to get any images of her -- I can't elevate, because there are no stands, and side/profile shots are hit-or-miss because her face will usually be obstructed by her arms.
Her bad habit is closing her eyes on the block -- on instinct, she thinks she'll get hit by the ball in the face. Which leads to shots like this -- probably a nice capture if she had her eyes open (and I spend some time in post)...
Keltab
May 19, 2016 00:19 |  #8
Very common habit for a middle... I've seen that even at the NCAA Sweet Sixteen. Not often though ߙ
She's got good extension, just a slight change with her hands and she could probably close down a lot more attacks.
Sorry - coach mode! Not sure if she would want advice...
Good image, and it is tough to capture with the net. You caught her extended and getting a hand on the ball.
Nice capture!
PhotosGuy
Joined Feb 2004
May 19, 2016 08:10 |  #9
Keltab wrote in post #18011744 (external link)
Zen volleyball! ; )
fourfa
Joined Nov 2015
May 23, 2016 17:55 |  #10
Great Shot :)
“Photography for me is not looking, it’s feeling. If you can’t feel what you’re looking at, then you’re never going to get others to feel anything when they look at your pictures.”
— Don McCullin
Conradebner
Gallery: 156 photos
Joined Jun 2012
Apr 07, 2017 22:18 |  #11
One of my favorites, just happens to be my daughter!
1DX, 70-200 2.8L IS II, 24-70 2.8L, 300 2.8L IS, 200 2.8L, 7D, 40D, 100 2.8 Macro, 580EX II
Www.IE3photo.com (external link)
landyclave3
Joined Apr 2017
Apr 10, 2017 11:40 |  #12
the photos are nice
5,794 views & 8 likes for this thread
Girls Volleyball
1000 guests, 317 members online
