I maintain a monthly subscription and want to plan ahead...were I to let my subscription permanently lapse...
what must I do to retain all the saved PSD/PSB files that occupy my HD in the event that they are to be printed at a later date?
May 13, 2016 10:23 | #1 I maintain a monthly subscription and want to plan ahead...were I to let my subscription permanently lapse... The things you do for yourself die with you, the things you do for others live forever.
kirkt Cream of the Crop More info Post edited over 7 years ago by kirkt. (4 edits in all) | May 13, 2016 10:46 | #2 Nothing. Kirk
May 13, 2016 12:15 | #3 Or, if you have a bunch of PSD files that you want to preserve create an action to save them all as TIFF files. They will be editable in other applications. Also change your current setting in CC to save TIFF files instead of PSD files so moving forward you won't have to convert them. Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
DagoImaging Goldmember More info Post edited over 7 years ago by DagoImaging. | May 13, 2016 12:16 | #4 http://photo.net/digital-darkroom-forum/00MBYp Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
May 13, 2016 12:26 | #5 Are you suggesting that each of the files must be opened and saved as a TIFF file? The things you do for yourself die with you, the things you do for others live forever.
May 13, 2016 12:31 | #6 Use Bridge, select all the files you want to convert and select Tools>Batch and that will launch CC and you select the action to run. Go eat lunch or go to bed....it's just time. Sony a7R3a/a6300/ 16-70/4 / 70-200/4 G / 12-24/4 G/ 24-105/4 G /Sony HVL-60M
Bcaps I was a little buzzed when I took this More info Post edited over 7 years ago by Bcaps. | May 13, 2016 12:31 | #7 chauncey wrote in post #18005828 Are you suggesting that each of the files must be opened and saved as a TIFF file? What about the rather large PSB files? TIFF has a 4GB file size limit so if the PSB files are larger than that they cannot be converted to TIFF. You could flatten some/all of the layers to get the file size smaller before converting and that should work. - Dave | flickr
May 13, 2016 12:38 | #8 TIFF has a 4GB file size limit so if the PSB files are larger than that they cannot be converted to TIFF. Ah...some of them are 14 GB...what then? The things you do for yourself die with you, the things you do for others live forever.
May 13, 2016 13:23 | #9 Flatten some layers, then save as TIFF. I doubt you'll be able to selectively flatten layers with a batch action, though. http://www.avidchick.com
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | May 13, 2016 14:09 | #10 Stop worrying, Adobe are not going to completely cut you off from either the apps, or your work. Bridge will continue to work as it is now completely free, and you should be able to download/install it independently using the Adobe manager app. I think you can print from Bridge so you will still be fine.
Hen3Ry Goldmember 1,063 posts Likes: 28 Joined Nov 2009 Location: Aptos, CA, USA More info | May 14, 2016 11:06 | #11
May 14, 2016 11:18 | #12 Saving PSDs with Maximize Compatibility set to Always in Settings/File Handling will ease potential problems. George
May 14, 2016 11:29 | #13 I think that I failed to explain my motivations...want my children to have the ability to view and/or print my images at a later date. The things you do for yourself die with you, the things you do for others live forever.
TomReichner "That's what I do." 17,636 posts Gallery: 213 photos Best ofs: 2 Likes: 8386 Joined Dec 2008 Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot More info Post edited over 7 years ago by Tom Reichner. | May 14, 2016 12:19 | #14 chauncey wrote in post #18006852 I think that I failed to explain my motivations...want my children to have the ability to view and/or print my images at a later date. Kind of an inheritance thingy. What do I gotta do? Well, in that case wouldn't the solution be to just take all of your finished images and export them to a folder as full resolution, top-quality jPegs? "Your" and "you're" are different words with completely different meanings - please use the correct one.
tonylong ...winded More info Post edited over 7 years ago by tonylong. | May 14, 2016 13:01 | #15 chauncey wrote in post #18006852 I think that I failed to explain my motivations...want my children to have the ability to view and/or print my images at a later date. Kind of an inheritance thingy. What do I gotta do? Yeah, Chauncey -- the answer would to me be pretty clear: Follow Tom's advice to save/export to jpegs so that the pics will be available in a one-touch process using any standard/generic picture viewer. You can "archive" the jpegs on a "main" hard drive so that your "audience" won't have to mess with external drives. Tony
| Latest registered member is semonsters 909 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
