Dan Marchant wrote in post #18008558
Lightroom's import screen allows you to rename files during import. It also allows you to save settings as an import preset to be reused. You can have multiple import presets for different cameras or differnt types of shooting.
I have it set to change files names to a prefix followed by YYYY-MM-DD followed by the original file name. Example: IM852-2016-06-13-9032.CR2 All I do it select the preset during import and the files are automatically renamed. The preset also creates a dated folder, copies the images into it,
make a back-up copy to another location, sets the colour to Green and adds a "To Do" keyword.
Good advice. I have several different import presets, that all follow my consistent standard.
My file naming convention is (Custom Text)_(YYYYMMDD)_(Filename number suffix).dng
The Custom Text is a prompt in the Renaming pane of the Import dialog. When I start the Import, I type in a meaningful word or phrase, such as "Dragoncon" or "Carter_Family_Christmas." That way, by simply looking at the filename, I know the context of the image and when it was taken.
I also use a meaningful folder hierarchy layout, though my Import presets just make a new folder in my "Current Work" folder - again, with a prompt for the folder name. The filed only go into the folder hierarchy once I'm done processing & delivering them.
I really need to use that "Make a backup copy" option. I'm starting to get really paranoid about my backups.
