Thread started 15 May 2016 (Sunday) 16:40
Canon 1D MK III ISO Setting
DarenM
May 15, 2016 16:40 |  #1
What am i missing? I am unable to set ISO lower than 200.
Canon 1D MK IV, Canon 1D MK III, Canon 5D, 24-70 2.8L, 70-200 2.8 L IS MK II, 17-40 F4 Canon, 430 EX, Canon A2E, 530EX Canon 1.4 Extender, 580 II, 600EX-RT, ST-E3-RT, (Way too much stuff for an amateur)
DarenM
May 15, 2016 18:30 |  #2
Anyone have any ideas ?
Snydremark
my very own Lightrules moment
Gallery: 66 photos
May 15, 2016 18:36 |  #3
Probably have Highlight Tone Priority turned on. Find wherever that lives in the settings and turn it off; then you should be able to go down to 100.
Bassat
"I am still in my underwear."
Joined Oct 2015
Post edited over 7 years ago by Bassat. (3 edits in all)
May 15, 2016 19:08 |  #4
If ISO is 2oo, HTP is turned on. If ISO is 200, you minimum ISO is set.
EDIT:
Minimum ISO setting is found under C.fn.I-3.
HTP is under C.fn II-3.
tonylong
...winded
Gallery: 60 photos
May 15, 2016 19:46 |  #5
Hey, it's funny, because when I first read this post, I drew a blank -- I had sold my 1D3 several years ago and so didn't have it (or the manual) in hand, and even though my memory got perked a bit, it couldn't recall the answer!
So, since no one had yet chimed in, I decided to move along until someone did, and sure enough, the answer came through, HTP!!
I did recall, though, once my memory got reminded, that I had run some quick tests on HTP to see how useful it may (or may not) be. Since the question had come up here in POTN, I decided to put the results in a PBase gallery and share them, and then life moved on, because since I shot/shoot RAW HTP didn't do me any good.
Anyway, here's a link to that gallery if you're interested:
http://www.pbase.com/t​onylong/mk3_htp_test (external link)
Tony
Bassat
Joined Oct 2015
May 15, 2016 20:44 as a reply to  @ tonylong's post |  #6
My guess is that the problem is NOT HTP. HTP would show an ISO setting of 2oo (lower case letters). OP makes no mention of an odd looking ISO value. A minimum ISO setting of 200 (numerals) can only come from having 'Minimum ISO' set to 200, and enabled.'
tonylong
...winded
Gallery: 60 photos
May 15, 2016 23:36 |  #7
Bassat wrote in post #18008284 (external link)
That could be, although if the OP is new to the HTP process, he/she could just not be used to distinguishing between "oo" and "00"! At this point we'd need to hear from the OP!
Tony
Bassat
Joined Oct 2015
May 16, 2016 00:44 as a reply to  @ tonylong's post |  #8
True. and True.
DarenM
May 16, 2016 05:04 as a reply to  @ Bassat's post |  #9
thank you for all your comments, I do have HTP set so I am sure that is it. Thanks again
Bassat
Joined Oct 2015
May 16, 2016 10:27 |  #10
:oops::oops::oops:
tonylong
...winded
Gallery: 60 photos
May 16, 2016 21:49 |  #11
Bassat wrote in post #18008796 (external link)
:oops::oops::oops:
But hey, you did provide valuable input!
Tony
2,082 views & 3 likes for this thread, 4 members have posted to it.
1548 guests, 135 members online
