Thread started 16 May 2016 (Monday) 10:16
5dmkIII w 1.4 tele and 70-200 f2.8 IS focus issue and speed?
bphillips330
May 16, 2016 10:16 |  #1
I just got my 5d mark III and loving it. But I am having some issues that I am not sure if user error, or issue with my camera.
I was shooting my daughters soccer match the other day my settings were this
Manual
1000 f4 -8 (playing around with settings)
AI-Servo
High speed shutter capture
Focus Mode is on the sport one that says recommended for sports. 4th Icon down on the focus screen I think, I don't have camera on me at the moment to look.
I have the focus on auto find subject.
70-200 f2.8 IS (couple year old lens)
canon 1.4 teleconverter (couple years old lens also)
Things I notice:
It keeps hunting and searching to lock focus. When I first test this it was perfect. Now it locks on and then looses and starts hunting around screen. I am not sure if the 1.4 teleconverter is causing the issue. I don't think this was an issue when I was not using it for testing when I first got camera. This an issue?
When I have it in high speed shutter, I think it is only taking 2-3 pics per second. When I change camera to AI-Focus then the shutter fires full speed. I think this is tying back to the focus issue from above.
Can the 1.4 teleconverter cause an issue?
Bassat
"I am still in my underwear."
Joined Oct 2015
May 16, 2016 11:13 |  #2
I use a 70-200 f/4L IS with 1.4x frequently on 6D and 1DIII. I notice no focus issues at all. Speed and accuracy is fine on both setups. I'm not sure how relevant that is to a 5D3, though.
gschlact
May 17, 2016 20:13 |  #3
bphillips330 wrote in post #18008781 (external link)
Manual
AI-Servo
Things I notice:
Your all points AF will typically lock on closest subject. I suggest you at least start with center point if using All points.
saea501
... spilled over a little on the panties
Gallery: 43 photos
May 18, 2016 16:01 |  #4
I've used the 2X tele with the 70-200 2.8 on my 6D and it causes a noticeable slow down in focus. No hunting, just slow.
So......I got the 100-400 II.......took care of the slow focus issue.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
ejenner
Gallery: 98 photos
Joined Nov 2011
May 18, 2016 22:56 |  #5
Make sure you are in 'case 1' AF mode and not on some super-sensitive mode. Also I'm not sure about 'auto find subject'. I only use a single point (with expansion). I never let the camera decide what to focus on.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 18, 2016 23:34 |  #6
...Can the 1.4 teleconverter cause an issue?
Absolutely, yes. Test without the T-Con and see for yourself if that solves the problem.
The 1.4XII on the original 70-200mm f/2.L IS should work well in decent lighting conditions, however the T-Con will always slow focus to some extent.
CDS' HOT LINKS
1,682 views & 0 likes for this thread, 6 members have posted to it.
1186 guests, 182 members online
