Is there a calculator out there that allows you to input your cameras sync speed as well as the aperture and iso that will then output how many stop ND filter you need to get down to your sync speed in broad daylight?
Alveric Goldmember More info Post edited over 7 years ago by Alveric. | May 18, 2016 16:10 | #2 Permanent banSunny 16. Go from there. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
dmward Cream of the Crop More info | May 18, 2016 18:30 | #3 Alveric wrote in post #18011391 Sunny 16. Go from there. Your sync speed is fixed, so just add as many ND filter densities as stops of aperture you open up. Sunny 16 = 1/200, ISO 100 @ f/11. Thus: @ f/8 — ND 0.3 (1 stop) @ f/5.6 — ND 0.6 (2 stop) @ f/4 — ND 0.9 (3 stop) . . . There are also apps for the iPhone and I presume Android that will do the calculating. David | Sharing my Insights, Knowledge & Experience
ImageMaker... looks like I picked a bad week to give up halucinagens More info Post edited over 7 years ago by ImageMaker.... | May 18, 2016 18:40 | #4 Some Ambient and studio flash meters will also do this... The Sekonic L-478DR-EL Nikons, Rolleiflexes, Elinchroms, Broncolor Paras, Billinghams
dmward Cream of the Crop More info | May 18, 2016 23:10 | #5 Angmo wrote in post #18011492 Some Ambient and studio flash meters will also do this... The Sekonic L-478DR-EL Better yet, take time to figure this out yourself too. It's fast and easy once you do it a few times. Nothing beats the mind of a good photographer to work problems! If your batteries run out, you'll have to do it anyway. It's really a very minor calculation. Just know and understand your f-stops. The key is knowing how many EV each of your ND filters block. David | Sharing my Insights, Knowledge & Experience
MalVeauX "Looks rough and well used" More info | May 18, 2016 23:50 | #6 Stregone wrote in post #18011383 Is there a calculator out there that allows you to input your cameras sync speed as well as the aperture and iso that will then output how many stop ND filter you need to get down to your sync speed in broad daylight? Heya,
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 7 years ago by Wilt. (4 edits in all) | May 19, 2016 23:15 | #7 Why not a chart like this one. http://f128.info/p/latex/ev_table.png
For example, let us assume we want to shoot at 1/250 f/8, ambient is 1/400 f/16 (we're assuming ISO 400 under Sunny 16 conditions)
Set your shutter on 1/250, f/stop to f/8, screw in an ND8 and shoot! The world is so darn reliant on automation that nobody knows how to THINK any more, when they don't have their calculators! The EV chart even works with the crazy -9EV and -10EV extreme situations. Like MalVeaux I have always simply did it all mentally without even the EV chart to lean on..."1/400 to 1/250 is about -0.66EV, f/16 to f/8 is -2EV, the needed filter is exactly -2.66EV. See, no chart! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
May 19, 2016 23:18 | #8 Permanent banWilt wrote in post #18012719 [..] The world is so darn reliant on automation that nobody knows how to THINK any more! Sometimes not even the coders of the apps and software we rely on! 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
AnnieMacD Oops, me again More info | May 21, 2016 07:58 | #9 They are the exceptions!
PhilV Goldmember 1,977 posts Likes: 75 Joined Jan 2005 Location: S Yorks UK More info | May 21, 2016 08:37 | #10 Like Wilt, I must be old. Gear List
LeftHandedBrisket Combating camera shame since 1977... More info | May 21, 2016 08:45 | #11 yup, practice plus experience and then you will just be able to figure it out. Reliance on letting someone else do it for you will keep you from experiencing the critical thinking that will help you become a better, more efficient photographer. PSA: The above post may contain sarcasm, reply at your own risk | Not in gear database: Auto Sears 50mm 2.0 / 3x CL-360, Nikon SB-28, SunPak auto 322 D, Minolta 20
PhotosGuy Cream of the Crop, R.I.P. More info | May 21, 2016 09:20 | #12 Alveric wrote in post #18011391 Your sync speed is fixed, ... True, but your recommended sync speed might be fudged a little. Depending on your camera & the situation, you might be able to use a higher sync speed: Strobe sync @ 1/400: Pushing the limits. FrankC - 20D, RAW, Manual everything...
| Latest registered member is griggt 1171 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
