Managed a few frames last night, shooting with my 480mm refactor with 4x TeleVue PowerMate. This is my first image of Mars with surface detail!!!
- Daniel
legoman_iac Senior Member 308 posts Likes: 50 Joined Nov 2009 Location: Sydney More info | May 22, 2016 16:04 | #1 Managed a few frames last night, shooting with my 480mm refactor with 4x TeleVue PowerMate. This is my first image of Mars with surface detail!!! - Daniel 2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
May 22, 2016 17:50 | #2 Congratulation!! Which scope did you use ? First one this year I've seen with detail .
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | May 22, 2016 17:59 | #3 Wow, very nice. Not sure why, but call me JJ.
May 23, 2016 15:18 | #4 This was shot with my Orion ED80T CF. Want to also try with my Orion StarMax 90mm TableTop Maksutov-Cassegrain, if I can find a way to mount the 4x TeleView (2") into the 1.25" ... would give me an effective 5000mm focal length, as opposed to th ED80's 1920mm ... and yes, I have focal length envy, hahaha. 2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
Canonuser123 Goldmember More info | May 23, 2016 16:06 | #5 legoman_iac wrote in post #18016515 if I can find a way to mount the 4x TeleView (2") into the 1.25" ... would give me an effective 5000mm focal length, as opposed to th ED80's 1920mm ... and yes, I have focal length envy, hahaha.
May 23, 2016 16:45 | #6 legoman_iac wrote in post #18016515 This was shot with my Orion ED80T CF. Want to also try with my Orion StarMax 90mm TableTop Maksutov-Cassegrain, if I can find a way to mount the 4x TeleView (2") into the 1.25" ... would give me an effective 5000mm focal length, as opposed to th ED80's 1920mm ... and yes, I have focal length envy, hahaha. Never really gone after the planets before, so much fun though!!! Good luck but personally I think you would be disappointed in the outcome image. Scopes depending the actual size are made to handle a certain amount of power effectively with a decent focus. Way over powering the scope with power mates or Barlows will degrade images to a certain point that will make them look soft or not sharp . The proper setup for you to use tho is with a 2" focuser and 2" diagonal and 2"EP . ONLY then will a power mate help in increasing the object size in the EP . The adapter mentioned from Amazon will only hender your viewing to a small FOV . Does your scope use a 2" focuser ?
May 23, 2016 17:22 | #7 Check this out on Telescope Power :
Celestron Cream of the Crop More info Post edited over 7 years ago by Celestron. | May 23, 2016 17:29 | #8 legoman_iac wrote in post #18016515 This was shot with my Orion ED80T CF. Want to also try with my Orion StarMax 90mm TableTop Maksutov-Cassegrain, if I can find a way to mount the 4x TeleView (2") into the 1.25" ... would give me an effective 5000mm focal length, as opposed to th ED80's 1920mm ... and yes, I have focal length envy, hahaha. Never really gone after the planets before, so much fun though!!! You have a 2" focuser , all you need is a 2" diagonal from Orion .
May 29, 2016 20:08 | #9 Howdy all, Compared to, 4x on my 480mm refactor: Also tried drizzle stack on both, though only kept the refactor's one: So I won't try this again, but was a fun test between gear to see real world differences. - Daniel 2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
May 29, 2016 22:01 | #10 I think you did a great job ! Mars is a very hard planet to image cause of the brightness . The easiest way tho is with video and then stacking the frames in a program like Registax or DSS . Just a short burst of video can produce 200 or more frames to stack but it's best to let the program discard the bad frames . But with what you do have be proud of cause like I say it's a hard planet to image !
Thanks Celestron, am proud of it ... though think I can probably push it a little more with my refactor. Also, these are about 70 subs each stacked. Yet to work how to shoot video as I'm using canin 50Ds, heard of magic lantern but yet to take the plunge. 2x 50d: with 17-85mm f4-5.6, 100mm Macro USM, 50mm f1.8, 2x Sigma 30mm f1.4, 55-250mm (kit lens), Canon 100-400mm L, Tamron 200-400mm f5.6, Samyang 8mm. 480mm refactor with HEQ5. Home made beamsplitter stereo rig.
Canonuser123 Goldmember More info Post edited over 7 years ago by Canonuser123. | May 30, 2016 03:54 | #12 legoman_iac wrote in post #18023415 Yet to work how to shoot video as I'm using canin 50Ds, heard of magic lantern but yet to take the plunge.
| Latest registered member is semonsters 1059 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
