I love the 4K Monitor for editing, its a dream , but I hit an issue last night.
I was using the Distort / Liquify tool; and althoughnthe mouse went exactly where I wanted it to, the shrink and expand functions didnt work properly.
Bt that I mean, if one wanted to shrink an item and set the usual size of brush, it was as though it wasnt responding properly. Instead of say expanding in a uniform way it was as though only a small effect was created. To rectify this I had to get the centre much closer to the line I wanted to change, and the effect was less than on the Laptop.
So I thought I would go and adjust it - brush sensitvity and pressure sensitivity. Ooops discovered these control boxes were greyed out?
Thinking I had an installation propblem, decided to try the old Laptop.
So I hopped over to the 1920x 1080p laptop, and then I discovered they were also greyed out.
This machine was also upgraded to Windows 10 Home.
Q. Does Elements 13 support Win 10 ?
But with the same size brush, on the Laptop it shrunk and expanded perfectly on the default setting.
So it looks like 2 issues
1. It appears PSE 13 isn't working properly on Windows 10.
2. Could this be a Monitor/GPU/Monitor issue - in 4K . Due to refresh rates etc.
This monitors native setting is 3840 x 2160 at 60 Hz. It says it has a Response time of 14ms grey to grey ( what is that) surely it refreshes every 1/60th of a sec?
I was considering upgrading to the newer 27" version in this lineup and that has a Response time of 6ms grey to grey.
Could this be the issue, or is it a GPU limitation? The GPU is MSI GTX 970 4GB RAM Gaming G4. SomImassume that is more than up to driving this monitor?
Q Does anyone have PSE 13 and Windows 10? Could they see if the brush pressure box is greyed out. NB I am really not very au fait with this sw.
Q Could the difference in reaction of the click on the shrink/expand feature be due tomthe monitor.
Any help appreciated.
Oh well my first negative regardi g the 4K screeen / setup.
But nit the end of the world as everything else seems perfect.
Am I right in that there is NO Support for Elements, just a user forum, that is hardly ever updated run by users?
