Thread started 27 May 2016 (Friday) 15:45
G9 Died ?????
frayne
Gallery: 54 photos
Joined Sep 2013
May 27, 2016 15:45 |  #1
My poor little G9 seems to have given up the ghost. Either that or the battery is just shot. Any idea to help me trouble shoot are appreciated in advance.
The only thing a golfer and photographer needs is more light.
Canon G9/5D/6D/70D Lenses 100-400L IS/17-40L/24-105L IS/100L IS/85 USM
denncald
May 28, 2016 14:31 |  #2
Others have been there with this or something like it. Here's one thread from several years ago
https://photography-on-the.net …/showthread.php​?t=1059781
Thankfully, I've never had the issue, and now my wife is using the G9 without issues.
Dennis
CarloY
Joined Sep 2009
Jun 08, 2016 01:44 |  #3
Don't like to learn of another G9 death. I hope it is not the camera itself. Denncald's right, with the screw-loose link.
Other things....
some people in the past have said remove the SD Card and the battery for X minutes (~15 min ??)
also, try powering ON into PLAY, rather than camera.
you can try other weird things... like no battery, no SD card, and then holding down the power Button and then insert the battery. Do test the battery for voltage (or help from a friend).
Lastly clean the battery contacts with a pencil eraser. And you can put the camera in a box with some rice or dessicant to wick out moisture.
Good luck.
G9's... enthusiast and hobby clicker... toying w/ Canon 2x Tele & Raynox .7x Wide.
frayne
Gallery: 54 photos
Joined Sep 2013
Jun 08, 2016 07:08 |  #4
Thanks Carloy, I bought, charged and tried a new battery, no luck there. Tried the S/D card and battery removal, nothing. Tried powering on in play mode ( I assume you hold both power on and play buttons at the same time) with no luck. Guess the next step is to open her up !
CarloY
Joined Sep 2009
Jun 09, 2016 09:48 as a reply to  @ frayne's post |  #5
There are services that will repair it with the 'exact' new board for your model/serial#, and calibrate everything for reasonable. A few years ago, that was approx. $100 plus shipping one direction.
IIRC, there are two boards that could 'die' because of the screw problem (of course, there may be other causes). IIRC, one is small, right under the power button. The other is a bit larger, behind the thumb wheel. Good luck.
Here's a link to one of the original posts, archived. Unfortunately, the pictures did not survive, but you may gain some extra info.
http://web.archive.org …/who-killed-my-g9-133.htm (external link)
2,788 views & 0 likes for this thread, 3 members have posted to it and it is followed by 2 members.
G9 Died ?????
1426 guests, 146 members online
