My 400 5.6 L has some scratches and paint chips,,nothing real bad ! but where can i get some matching canon white touch up paint ??
Thanks Ron
RonnieH Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | May 29, 2016 07:16 | #1 My 400 5.6 L has some scratches and paint chips,,nothing real bad ! but where can i get some matching canon white touch up paint ??
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | May 29, 2016 07:46 | #2 Not sure why, but call me JJ.
RonnieH THREAD STARTER Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | May 29, 2016 09:59 | #3 The review on that paint says it matches color good,,but does NOT stick good ??any more Ron
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | May 29, 2016 10:09 | #4 Permanent banYou are aware that Canon makes two different colors of 'white' lenses, right? Just in case you are interested in the 'white', not the 'tan' above:
May 29, 2016 10:23 | #5 Bassat wrote in post #18022637 You are aware that Canon makes two different colors of 'white' lenses, right? Just in case you are interested in the 'white', not the 'tan' above: http://www.amazon.com …fRID=1GG848YXNSVW6CE99432 yup... some are white some are tannish tone. The 1.4xIII white does not match the 200L white. I can see a difference with the two when side/by/side A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
RonnieH THREAD STARTER Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | May 29, 2016 10:25 | #6 I will have to check close ?i think mine is the white ??
RonnieH THREAD STARTER Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | May 29, 2016 10:26 | #7 this is the canon 400 5.6 L,,, ??
nellyle Goldmember More info Post edited over 7 years ago by nellyle. | May 29, 2016 11:12 | #8 Pretty sure that the 400 5.6 will be the older white, the new white is used on the version ii superteles, 100-400ii and I think the 70-300 (not sure about the 70-200 ii) 5D3, 7D2, 1D3, 40D, 14 f2.8 Samyang, 17-40 L, 28-80 L, 70-200 2.8ii L, 200 2.8ii L, 200-400 L, 1.4 ii,
May 29, 2016 11:49 | #9 nellyle wrote in post #18022695 Pretty sure that the 400 5.6 will be the older white, the new white is used on the version ii superteles, 100-400ii and I think the 70-300 (not sure about the 70-200 ii) Here you go, scroll down to the image with the lenses lined up, you can see the difference in colour there. http://www.the-digital-picture.com …S-II-USM-Lens-Review.aspx I would agree. The 1.4xiii is definately a purer white than the 200L A7rIII | A7III | 12-24 F4 | 16-35 GM | 28-75 2.8 | 100-400 GM | 12mm 2.8 Fisheye | 35mm 2.8 | 85mm 1.8 | 35A | 85A | 200mm L F2 IS | MC-11
CyberDyneSystems Admin (type T-2000) More info Post edited over 7 years ago by CyberDyneSystems. | May 29, 2016 12:11 | #10 These two combined will get either color mixed together. Add more white for the new L. GEAR LIST
RonnieH THREAD STARTER Goldmember 1,793 posts Likes: 53 Joined Feb 2009 Location: Twining, Michigan USA More info | May 29, 2016 13:15 | #11
msowsun "approx 8mm" More info | May 30, 2016 00:11 | #12 Early EF 70-200mm 2.8 IS II and EF 2x Mk III Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.4 USM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
| Latest registered member is semonsters 1099 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
