Thread started 03 Jun 2016 (Friday) 12:09
Technical Problem: 60D aperture dial doesn't work
drmaxx
Gallery: 41 photos
Jun 03, 2016 12:09 |  #1
On my Canon 60D in manual I can not change the aperture anymore. It is fixed on 13. I can change it in the other modes - so probably not a aperture problem. Same thing for different (Canon) lenses. The setting for the dial lock is disabled - can't be this setting.
Any other ideas? Is there an option to reset the entire camera?
Donate if you love POTN
rrblint
Gallery: 84 photos
Joined May 2012
Jun 03, 2016 12:14 |  #2
Are you using a battery grip on the camera?
Mark
drmaxx
Gallery: 41 photos
Jun 03, 2016 12:17 |  #3
No battery grip.
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Jun 03, 2016 12:40 |  #4
There should be an option to reset camera settings and one to reset custom functions; the second would be the suspscious one in my mind.
BigAl007
Gallery: 556 photos
Jun 03, 2016 13:16 |  #5
On the older XXD bodies,such as my 50D there is two positions on the power switch, one of which locks the rear wheel. On the newer XD cameras there is a separate switch for the wheel lock. I am sure that there must also be an option on the 60D that has the same function to lock out the rear wheel. I would suspect that this has be accidentally set to lock out the rear wheel.
Alan
drmaxx
Gallery: 41 photos
Jun 03, 2016 13:34 |  #6
BigAl007 wrote in post #18027992 (external link)
Alan
I am only aware of a setting to engage the lock with the option of using an UNLOCK button to release this lock temporarily. If anybody knows of an other hardware based lock - please let me know.
drmaxx
Gallery: 41 photos
Post edited over 7 years ago by drmaxx.
Jun 03, 2016 13:35 |  #7
Using the menu for resetting the camera did not change anything.
I am afraid that I need to get this repaired. What a bummer. May be a good excuse to get an upgrade?:lol:
Snydremark
Gallery: 66 photos
Jun 03, 2016 13:40 |  #8
drmaxx wrote in post #18028014 (external link)
Did you do both of the resets? Camera Settings AND Custom Settings?
NullMember
Jun 03, 2016 13:44 |  #9
bannedPermanently
drmaxx wrote in post #18027916 (external link)
Does the rear dial still operate correctly in conjunction with other functions?
drmaxx
Gallery: 41 photos
Jun 03, 2016 14:21 |  #10
Snydremark wrote in post #18028018 (external link)
Yes.
john crossley wrote in post #18028021 (external link)
I couldn't find anything. Exposure compensation (in TV) or any other settings I try to adjust with the wheel fails.
JWdlft
Joined Feb 2013
Jun 03, 2016 14:35 |  #11
The second "wrench" menu, bottom option, Lock (*) wheel. If you disable that, the Unlock button will be superfluous. If Lock is enabled, the unlock button unlocks the wheel for 4 seconds.
See page 42 of the English language manual > Using the UNLOCK button
drmaxx
Gallery: 41 photos
Jun 03, 2016 14:46 as a reply to  @ JWdlft's post |  #12
Thanks JWdlft - unfortunately that's not the problem. It is disabled.....
JWdlft
Joined Feb 2013
Post edited over 7 years ago by JWdlft.
Jun 03, 2016 14:53 |  #13
Does the wheel work to scroll through photos (backward and forward) when viewing on your SD card? The Lock function should not effect that.
drmaxx
Gallery: 41 photos
Jun 03, 2016 15:28 |  #14
JWdlft wrote in post #18028068 (external link)
Nope:cry:
JWdlft
Joined Feb 2013
Jun 03, 2016 15:32 |  #15
Oops, I'm starting to think there's a camera problem, but I guess you feared that already.
I'm sorry, I can't think of anything else, except maybe remove the battery for a day or so, see if that changes anything.
Good luck.
5,397 views & 0 likes for this thread, 7 members have posted to it and it is followed by 3 members.
1131 guests, 166 members online
