My recommendation would be:
Instead of looking for a motel with an early check-in, I would call motels and ask if they charge extra for an early check-in. In other words, you're asking if they are willing to change their normal check-in time to accommodate you. I have done this on several occasions (but usually I am requesting late checkout instead of early checkin), and only been refused one time. Every other time, the motel people were willing to change their normal schedule to accommodate me, at no extra charge.
Most motels, at least the ones I stay in, only rent a small percentage of their rooms, and most of the rooms sit vacant night after night after night. Hence, an early check-in shouldn't require them to have to clean a room early, as there are probably a bunch of clean rooms just sitting there waiting for someone to rent them.
