Between Grave yard at Blue Ridge: Pentax 16-45mm mounted on K-5
Jun 10, 2016 13:33 | #1 Between Grave yard at Blue Ridge: Pentax 16-45mm mounted on K-5 Image hosted by forum (797999) © junglialoh [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (798000) © junglialoh [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Jun 11, 2016 08:10 | #2 Located Between Grave Yard and Pisgah Mountain
dashotgun Goldmember More info | would be a lot better if you used a grad neutral density filter either in post or shooting and or exposed for the sky instead of the trees. the blown sky does nothing for the image. You don't take a photograph, you make it. ~Ansel Adams
I never used neutral density filter. in the future I will try as you recommended. Thanks to your insight.
dashotgun Goldmember More info | graduated nd, depending on the exposure IF you use RAW you might get something back from the sky alternately you do a composite with clouds and blend them together using layers You don't take a photograph, you make it. ~Ansel Adams
I learn that graduated ND filter is more effective, but expensive.
| Latest registered member is Thunderstream 1861 guests, 98 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
