How do you achieve the dramatic looking sky for portraits.
silvermesa1 Member 145 posts Likes: 17 Joined Aug 2013 Location: Columbia, Mo. USA More info Post edited over 7 years ago by silvermesa1. | Jun 19, 2016 13:32 | #1 How do you achieve the dramatic looking sky for portraits.
Alveric Goldmember More info Post edited over 7 years ago by Alveric. | Jun 19, 2016 13:41 | #2 Permanent banBy underexposing the ambient by at least two stops. I use a 3-stop ND grad and studio flash. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
dmward Cream of the Crop More info | Jun 19, 2016 13:56 | #3 Either ND filter or TTL depending on circumstances. David | Sharing my Insights, Knowledge & Experience
MalVeauX "Looks rough and well used" More info Post edited over 7 years ago by MalVeauX. (2 edits in all) | Jun 19, 2016 14:05 | #4 silvermesa1 wrote in post #18044096 How do you achieve the dramatic looking sky for portraits. Heya, Image hosted by forum (799719) © MalVeauX [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Very best,
dmward Cream of the Crop More info | Jun 19, 2016 16:23 | #5 MalVeauX wrote in post #18044123 ... I use ND filters to be able to not use HSS, and stick to sync speed (I do this so that I can use a light meter and get it right, fast, without just chimping; great for when time is of the essence).... That's one reason I generally use TTL and HSS, save lots of time once one has practiced enough to be confident with it. David | Sharing my Insights, Knowledge & Experience
aztecdaz Senior Member 285 posts Likes: 89 Joined Jul 2009 Location: Scotland More info | Jun 20, 2016 11:46 | #6 Either HSS or shoot stopped down to under expose the ambient. 5DIII Gripped | 5DII+wft-e4II | Gripped 7D | 24-70L | 70-200 2.8L IS | 85LII |17-40 L | 600ex-rt x3 | st-e3-rt |Quadra A Heads | BRX500 x 4 | lots of Rotalux Goodies
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 7 years ago by Wilt. (4 edits in all) | Jun 20, 2016 21:45 | #7 The key to imcreased drama in the sky is to reduce the DIFFERENTIAL of brightness between the sky and your primary subject.
You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Jun 20, 2016 21:52 | #8 Permanent banAnother downside of HSS is that you can't meter it with an incident meter: forcing you to eyeball it, which is not the best way to obtain consistent results, especially when you're chimping under bright daylight. 'The success of the second-rate is deplorable in itself; but it is more deplorable in that it very often obscures the genuine masterpiece. If the crowd runs after the false, it must neglect the true.' —Arthur Machen
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 7 years ago by Wilt. (2 edits in all) | Jun 20, 2016 22:09 | #9 Alveric wrote in post #18045396 you can find exactly how many stops and fractions of a stop your particular filter blocks light. Even within the same brand there are variations: my 82mm B+W Kaesemann is ~2 stops, whereas my 67mm B+W Kaesemann is only 1 stop.
So while #2 - #1 (1.5EV) shows the overall reduction across the ENTIRE scene (i.e. neutral density), #2 - #3 (0.7EV) shows the change in differential between the sky vs. main subject due to action of polarization. Admittedly, if I repeat the tests closer to midday, rather than close to dusk, the differential change may increase, but that is a test for another day. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
dmward Cream of the Crop More info | Jun 20, 2016 23:44 | #10 With the 300 and 600Ws strobes available today that do HSS and TTL, it is possible to get dramatic skys using HSS. David | Sharing my Insights, Knowledge & Experience
silvermesa1 THREAD STARTER Member 145 posts Likes: 17 Joined Aug 2013 Location: Columbia, Mo. USA More info Post edited over 7 years ago by silvermesa1. | I've seen some environmental portraits that looked out of this world to me. You could say the background was enhanced a bit but looks believable and natural.
dmward Cream of the Crop More info | Jun 21, 2016 13:50 | #12 Something like this? David | Sharing my Insights, Knowledge & Experience
silvermesa1 THREAD STARTER Member 145 posts Likes: 17 Joined Aug 2013 Location: Columbia, Mo. USA More info | Jun 21, 2016 16:25 | #13 Thank you for posting photos dmward and MalVeaux! Nice photographs. Those are indeed, in the direction I want to head. They both have saturation and are believable.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 7 years ago by Wilt. (2 edits in all) | Jun 21, 2016 16:41 | #14 Wilt wrote in post #18045414 I just did a test with my B+W CPL filter, measurements taken with a Minolta spot meter, in relative brightness mode (not f/stop readings, but EV difference readings from some baseline)
So while #2 - #1 (1.5EV) shows the overall reduction across the ENTIRE scene (i.e. neutral density), #2 - #3 (0.7EV) shows the change in differential between the sky vs. main subject due to action of polarization. Admittedly, if I repeat the tests closer to midday, rather than close to dusk, the differential change may increase, but that is a test for another day. I just did another measurement, this time at 2:30pm at a northern sky (vs. a southern sky about 7:30pm yesterday)
So while #2 - #1 (0.6EV) shows the overall reduction across the ENTIRE scene (i.e. neutral density), #2 - #3 (1.8EV) shows the change in differential between the sky vs. main subject due to action of polarization. I am not surprised that the differential change, in reduction of the 'glare' in the sky, is different today than yesterday (1.8EV vs. 1.5EV), due to the direction of the sky change (S vs. N) and also time of day (near dusk vs. mid afternoon). But comparing results from yesterday vs. today, I find it very puzzling how the overall ND effect of the CPL can be -1.5EV yesterday, yet only -0.6EV today! I repeated the tests FOUR times today and metering the sky produced the -0.6EV minimum effect, and then measured an interior wall which verified the -1.5EV fundmental differential of the filter ![]() You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
dmward Cream of the Crop More info | Jun 21, 2016 18:30 | #15 silvermesa1 wrote in post #18046162 Thank you for posting photos dmward and MalVeaux! Nice photographs. Those are indeed, in the direction I want to head. They both have saturation and are believable. Just as a personal preference, I'm looking to saturate the sky's a bit more even. Just imagine a landscape shot with saturated colors that push it a bit but you say to yourself, it could look like that. Then with the subject in the foreground exposed with off camera strobe. I imagine, not everyday is created the same for this type of portrait. Cloud structure and the type of sunset vary with different parts of the country and the day. Thank You! One thing to remember, if you want it to look realistic is that the sky is bluer the farther from the horizon because of atmosphere. David | Sharing my Insights, Knowledge & Experience
| Latest registered member is Monkeytoes 1322 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
