How do you shoot the stars from a boat?
The boat is over 300 ft long with a large deck.
What settings and lens would you suggest?
Due to boat movement and engine vibration a long shutter speed with or without a tripod is out
Ontario55 Member 69 posts Likes: 13 Joined Dec 2005 More info | Jun 21, 2016 08:08 | #1 How do you shoot the stars from a boat?
gjl711 Wait.. you can't unkill your own kill. 57,733 posts Likes: 4065 Joined Aug 2006 Location: Deep in the heart of Texas More info | Jun 21, 2016 08:15 | #2 You really have few option. As you mentioned, long shutter speeds are not an option because the boat is always moving so experiment and see what's the slowest you can get away with, use your fastest glass, and bump the ISO as high as you can. You can also try using one of the astro stackers and see if you get better results stacking multiple images. Not sure why, but call me JJ.
MalVeauX "Looks rough and well used" More info Post edited over 7 years ago by MalVeauX. | Jun 21, 2016 08:17 | #3 Ontario55 wrote in post #18045728 How do you shoot the stars from a boat? The boat is over 300 ft long with a large deck. What settings and lens would you suggest? Due to boat movement and engine vibration a long shutter speed with or without a tripod is out Thanks Heya,
Ontario55 THREAD STARTER Member 69 posts Likes: 13 Joined Dec 2005 More info Post edited over 7 years ago by Ontario55. | Jun 21, 2016 08:23 | #4 I should have mentioned that I was planning on shooting this with a Canon 5D MK 111 and my 24-70 2.8 lens, which is non IS
MalVeauX "Looks rough and well used" More info | Jun 21, 2016 08:30 | #5 Ontario55 wrote in post #18045743 I should have mentioned that I was planning on shooting this with a Canon 5D MK 111 and my 24-70 2.8 lens, which is non IS All you can do is max the ISO, wide open the lens, and take exposures at the lowest tolerable shutter speed you can manage at 24mm since you have no stabilization and no mount.
Thanks for all the info and suggestions. It is a large lake (not one of the Great Lakes so movement will be less than a Cruise ship at sea (or hopefully it will be).
JohnfromPA Cream of the Crop 11,258 posts Likes: 1527 Joined May 2003 Location: Southeast Pennsylvania More info | Jun 21, 2016 16:18 | #7 Ontario55 wrote in post #18045862 If possible I'll try to get near the center of the boat to lessen any side to side and front to back effects. If that doesn't help, then run the boat aground.
| Latest registered member is semonsters 1036 guests, 115 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
