Thread started 25 Jun 2016 (Saturday) 12:44
moon on 6-22-16
DanThoman
Jun 25, 2016 12:44 |  #1
I haven't posted in a while so I thought I'd share a couple of shots from Wednesday. Hope you enjoy them.
Plato
IMAGE: http://thomanstudio.com/img/s11/v32/p1901252423-5.jpg
Tyco
IMAGE: http://thomanstudio.com/img/s2/v1/p1995134088-5.jpg
Dan
my gear
Celestron
Jun 25, 2016 19:07 |  #2
Nice close ups but definitely over processed :( . The moon isn't that dark . Can you post your original unprocessed images ?
DanThoman
Jun 27, 2016 09:15 |  #3
There wasn't much processing done on these. These are AVI files of 1000 frames. The 50 best frames were stacked in autostakkert and then I used LR to sharpen the image and reduce the noise. I'm not sure what happened when I uploaded these but the image of Tyco is terrible. I'll give it another go and try and find what I did wrong. The images looked much better on my computer.
Actually, if you use a variable polarizing filter to remove glare parts of the moon are very dark.
Thanks for commenting.
Dan
my gear
DanThoman
Jun 27, 2016 12:44 |  #4
Here is the unprocessed and re-processed version of Tyco. I downloaded and used the newest version of autostakkert. Surprisingly, it would not stack the Plato AVI nor would registax6.
un-processed (stack of 50 frames)
IMAGE: http://thomanstudio.com/img/s3/v23/p1928502766-4.jpg
processed
IMAGE: http://thomanstudio.com/img/s4/v67/p1943395430-4.jpg
Dan
my gear
Celestron
Jun 27, 2016 12:59 |  #5
Bottom two look much better. I know now what the problem is , that polarizing filter. Not a good moon filter cause it's not even in protection . You need a regular moon filter . They have an even protection of glare throughout and should not darken darker areas of the moon like the way it is in your images.
DanThoman
Jun 28, 2016 09:33 |  #6
The filter is a variable moon filter made by orion. I get the same results when I use a regular moon filter.
Dan
my gear
TCampbell
Gallery: 13 photos
Joined Apr 2012
Jun 28, 2016 10:13 as a reply to  @ DanThoman's post |  #7
If you used the wavelets on Registax then you may have adjusted settings in such a way that it was over sharpening.
The "wavelets" work by looking for edges or borders of contrast ("structure") and then amplifying that contrast. This has an effect that a bit like "edge sharpening" in that it makes the bright side of the edge bolder and brighter and the dim side gets darker. But if over-done it starts to look like an impressionist's painting.
Celestron
Jun 28, 2016 11:46 |  #8
DanThoman wrote in post #18052225 (external link)
Do you have a Meaded ND96 Filter ? If you do try that instead of the Polarizing filter . Celestrons new Moon Filter is med green but I have not tried that one before so I have no idea if it causes a green cast in images or not however if switched to grayscale it wouldn't matter anyway .
https://www.astronomic​s.com …ch-moon-filter_p3824.aspx (external link)
http://www.meade.com …000-moon-filter-nd96.html (external link)
Crooks
Joined May 2012
Jul 15, 2016 13:27 |  #9
Nice close ups!
3,085 views & 2 likes for this thread, 4 members have posted to it.
moon on 6-22-16
926 guests, 115 members online
