Thread started 04 Jul 2016 (Monday) 01:45
Canon 600EX-RT question
NemethR
Joined Jun 2012
Jul 04, 2016 01:45 |  #1
Hello Guys,
I just ordered a Canon 600EX-RT Mk.II, and a ST-E3-RT.
But something got me wondering, and I did not find an answer to this via google.
It is possible, to use a 600EX-RT in Radio Slave, and Optical Master at once?
For example:
I have the ST-E3-RT on camera, use that to trigger the 600EX-RT,
while the 600EX-RT could trigger other Canon flashes in optical mode?
(430EX, 580EX).
Roland | Amateur Photographer
Nikon D850 | Nikon D80 | Nikon 70-200 f/2.8G ED VR II | Nikon 24-70 f/2.8G ED
Ah-keong
Gallery: 132 photos
Joined Apr 2016
Jul 04, 2016 02:37 |  #2
based on the mark I, I don't think you can set the speedlite in radio slave mode and optical master mode to function together.
Canon R3 | RP | 7D2+grip | EF 70-200mm f/2,8L IS II | EF 135mm f/2L | EF 50mm f/1,2L | RF 100mm f/2,8L | Tamron 24-70mm f/2,8 VC G2 | Tamron 17-35mm f/2,8-4 Di OSD | ZE 2/100mm | ZF 2/35mm | ZF 1,4/85mm | ZF 2/135mm | CV 1,4/58mm Nokton | Micro-Nikkor 60mm f/2,8D | DC-Nikkor 105mm f/2D | Micro-Nikkor 200mm f/4D |
Speedlite 430EX III-RT | 600EX-RT |
Manfrotto BeFree Travel | MT055XPRO3 |
NemethR
Joined Jun 2012
Jul 04, 2016 02:46 as a reply to  @ Ah-keong's post |  #3
Thank you.
Tbh. I did not think it is possible, it just came to my mind, maybe.
Well, ok, then I will have to use the 600 on the Camera, if I want to trigger other (optical) flashes.
- Not that I have any, but sometimes I borrow a few.
Ah-keong
Gallery: 132 photos
Joined Apr 2016
Jul 04, 2016 02:49 |  #4
welcome,
I think they are phasing out the optical type with the radio type.
Maybe you want to get multiple 600EXs to trigger :D
NemethR
Joined Jun 2012
Jul 04, 2016 05:58 |  #5
Ah-keong wrote in post #18057379 (external link)
That is the plan, more are to come for Xmas.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Post edited over 7 years ago by apersson850.
Jul 04, 2016 09:19 |  #6
In your example, it's the ST-E3-RT that's the master, not the 600 EX-RT II. There is only one master in the system. For your idea to work it would be a requirement that it's the 600 EX-RT II that's the master on the camera. Then it could have worked, if it would have been possible to have both radio and optical master enabled at the same time.
Unfortunately you can't. That's probably because the feature set available for optical vs. radio masters isn't identical. Thus you have to settle for either optical or radio master.
Using separate flash triggers, it could be possible to trigger the slave via radio, and then trigger "next level slaves" via light from the first slave. No automation in flash exposure that way, though.
Don't forget the cheaper, but still capable, 430 EX III-RT flash.
Anders
Submariner
Joined May 2012
Jul 05, 2016 18:08 |  #7
I am wondering if budget is driving you along this route.
I have 4x 600 Ex Rts all triggered by the STE 3 .
I did have 2 of the 430 optical flashes before , I would never ever go back to that optical route.
However I did have 2x cheap Yongnuos spare , these have an optical cell on them and they are a great budget way of getting additional fire power cheaply.
E.g.
Shooting a model in woodlands. Basicslly 2x 600s fill flash the head and bust, the other 2x 600s do from the waist to feet.
If say I want some of the woodland background illuminated, these are set manually and are set to the internal optical cell triggers. So the 600s do all the clever ettl2 fill flash stuff on the model and the 2x yongnuos (£40 each ) illuminate the background woodland. They fire every time, just a bit of a pain manually setting them to output the right light level, but one gets pretty good at guessing the power level.
The main thing is they cost £80 for 2, and the same power in 600s would have cost me £850!
And the nice thing is the model will be illuminated perfectly, well accurately, by The 600s .
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
crbinson
Joined Jul 2012
Jul 05, 2016 18:55 |  #8
For <$50 ea the YNE3-RX will allow you to incorporate the 430 & 580 into your radio system.
My Flickr (external link) | My Gear List
NemethR
Joined Jun 2012
Jul 08, 2016 12:44 |  #9
Submariner wrote in post #18058839 (external link)
E.g.
Thanks for the answer...
Not really a budget, issue, but partially it is.
I had to get a flash, but did not have the budget to buy 2, but I wanted a trigger.
So until i get a 2nd 600EX II-RT, I was thinking if i can use a 580EX II of my friend together with the radio system.
But I figured, I can use a YN flash that can be triggered by any optical flash.
Until I get a 2nd 600EX (sometime around October) it will do the job :)
I did not plan to buy the 600EX now, but I had to, for a project.
I can only say: This radio system is amazing :)
inkista
Post edited over 7 years ago by inkista. (2 edits in all)
Jul 08, 2016 22:01 |  #10
NemethR wrote in post #18061376 (external link)
... So until i get a 2nd 600EX II-RT, I was thinking if i can use a 580EX II of my friend together with the radio system.
You can, if you get the YN-E3-RX (external link) radio receiver or Phottix Laso receiver (external link), and attach it to the 580EXII.
... or you could consider the YN-600EX-RT (external link), if this is for hobbyist (non-pro) use. (See this thread for arguments for/against). Here in the US, they're going for $120.
I'm a woman. I shoot with a Fuji X100T, Panasonic GX-7, Canon 5DmkII, and 50D. flickr stream (external link)
3,299 views & 6 likes for this thread, 6 members have posted to it and it is followed by 2 members.
1506 guests, 136 members online
