I have a Tamron 28-75 XR Di 2.8 lens that gives an Err 01 when I attach it to the camera.
Is it worth sending into repair at this point? I have had for a long time just sitting around.
dalto Senior Member 758 posts Likes: 16 Joined Apr 2009 Location: Austin, TX More info | Jul 09, 2016 21:00 | #1 I have a Tamron 28-75 XR Di 2.8 lens that gives an Err 01 when I attach it to the camera.
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Jul 09, 2016 22:03 | #2 Permanent banI believe ERR 01 is a communication error. It takes two to communicate. The camera may be as much at fault as the lens. Clean the contacts on both.
Jul 09, 2016 22:17 | #3 What he said. my gear: T4i - EF-s 17-55, Ef-s 55-250 is stm, EF-S 10-22 usm, ef 100mm 2.8 macro
Jul 09, 2016 22:19 | #4 I should have mentioned it happens on two different cameras and I have tried cleaning the contacts.
Bassat "I am still in my underwear." 8,075 posts Likes: 2742 Joined Oct 2015 More info | Permanent banIn that case, I wouldn't fix it. The 28-75 is an inexpensive mediocre lens. At the wide end, my copy needed f/4 to be use-ably sharp. At the long end, it was pretty good wide open, but I am starting to want IS at that focal length. Upgrade time!
Jul 10, 2016 11:51 | #6 OK, I have other lenses that I actually use. I came across this one when I was cleaning out the closet.
| Latest registered member is Monkeytoes 1356 guests, 163 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
