Thread started 10 Jul 2016 (Sunday) 04:14
5d3 AF hit rate
Silver-Halide
Joined Jan 2015
Jul 10, 2016 04:14 |  #1
So I just shot another wedding, and I'm starting to get frustrated with the 5dIII AF. I feel I should be getting a better hit rate. I use BBAF on both the body and my non-OEM battery grip. I keep the camera in AI Servo and have an equally high miss rate when tracking a moving person as opposed to focus and recompose. I'm not trying to focus and recompose on a moving subject. When I focus and recompose I'm hitting the eye, then releasing the AF-On button, recomposing, and hitting the shutter. I only use the cross-type AF points. Shutter speeds equal to or greater than reciprocal focal length rule. Seems to be happening with a variety of even fast lenses: 50mm f/1.2L, 70-200mm f/2.8 II, etc. In the AF Config screen, I'm using Case 1. For sensitivity for both the first shot and second shots I have it set in the middle between |- release - and - focus -| I hope that should cover all the diagnostic questions--I don't think my technique sucks.
It seems as though the AF design of the 1dx and the 5dIII are the same? Getting a case of GAS? :oops:
aladyforty
Gallery: 398 photos
Best ofs: 5
Jul 10, 2016 04:42 |  #2
Silver-Halide wrote in post #18062787 (external link)
I know people poo poo AI focus but I run my 5DIII on that pretty much all the time regardless of if Im shooting moving or still subject usually on case 2, I have a very good in focus rate, Id say at least 97%
FUJI XT5 + XT3 & a bunch of Fuji lenses, Mavic Air2 drone
https://www.flickr.com​/photos/25426422@N00/ (external link)
bildeb0rg
Gallery: 821 photos
Post edited over 7 years ago by bildeb0rg.
Jul 11, 2016 11:21 |  #3
Plus one for a change to ai focus. If the light was particularly bad I would also defocus for each shot as it seemed the further the lens had to focus the more accurately it acquired. I would try using a focus point closer to the area you want to focus on rather than focus and recompose.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed.
Jul 11, 2016 12:41 |  #4
I used my 5D3 with the 70-200 2.8 during NBA seasons, and AF was good enough to track players. I think I used case 4 though. I am sure the 5D3 is adequate for wedding action shots if basketball posed no real issues. If you are having issues with all lenses (I wouldn't think the 50L is a good test mule for a good AF system though, but the 70-200 should be), then perhaps try resetting everything and resetting them, or send it in for a once-over.
gossamer88
"something else"
Gallery: 94 photos
Joined Aug 2014
Jul 11, 2016 12:49 |  #5
Agreed that AI Focus is the best of both worlds. Not to mention worry-free.
EOS R5 | EOS R7 | iPhone 12 Pro
RF 100-500mm | RF 100-400mm | RF 800mm F11 | RF 600mm F11
RF 24-240mm | RF 50mm 1.8 | RF 35mm 1.8 Macro | RF 16mm 2.8
NullMember
Jul 11, 2016 13:49 |  #6
bannedPermanently
You say you are using the AF-ON button to BBF; you did disable focusing from the shutter button first didn't you?
Silver-Halide
Joined Jan 2015
Jul 11, 2016 15:15 |  #7
john crossley wrote in post #18064101 (external link)
Yes, thank you. Great question.
absplastic
Gallery: 40 photos
Post edited over 7 years ago by absplastic.
Jul 12, 2016 14:35 |  #8
Missing from your initial description is information about what apertures you're shooting at, and how much you're recomposing. With fast lenses, it certainly matters. Also, what is the lighting like, bright, dim, colored? I ask because I've noticed that when shooting with my 85L, it is sometimes tricked in very low light and strongly-colored lighting situations (e.g. club with blacklights). It will appear to find and lock focus normally, but it's consistently off. The 100/2.8L on the other hand nails focus in the same situations. In bright light, the 85L has no such issues.
Also, if you're shooting wide apertures like f/1.8 or wider, there is no such thing as a "non-moving subject" unless you're actually using a tripod and shooting a still life. If you're handholding the camera and shooting people, any time recomposing or between button presses allows for critical focus to be lost after AF lock. And of course recomposing itself could be an issue, and not just at the widest apertures depending on subject distance, focal length, etc.
5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
SL1, 10-18 STM, 18-55 STM, 40 STM, 50 STM
My (mostly) Fashion and Portraiture Instagram (external link)
flickr (external link) (NSFW)
Silver-Halide
Joined Jan 2015
Jul 12, 2016 22:24 |  #9
absplastic wrote in post #18065168 (external link)
Yes, thanks. I know that if I'm shooting at f/1.2 and focusing half a meter away, that a large arc of focus-and-recompose will put an eye out of the depth of field. That's largely not my expectation and I DO look at the depth of field charts for the wider apertures I often, but not always, shoot at.
I'm not sure what you mean here, could you maybe try explaining this another way? Thanks.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jul 12, 2016 23:59 as a reply to  @ Silver-Halide's post |  #10
He means that at such narrow apertures any delay between focus and shoot is enough for your stationary child to twitch or your hand move fractionally thus moving the paper thin DoF and throwing the intended area of focus off, so you get a nose instead of an eye.
Dan Marchant
Lyndön
Jul 13, 2016 00:29 |  #11
I've been pleased with my 5D III AF, and I've shot everything from portraits and weddings to sports (soccer and softball) with it. I haven't had any consistent issue with out of focus shots except when used in low light with AF-assist and non-Canon (YN) flashes. A switch to an OEM Canon flash solved that.
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Jul 13, 2016 02:15 |  #12
Lyndön wrote in post #18065602 (external link)
Ditto, It mine has been a rock solid performer.
Dan Marchant
absplastic
Gallery: 40 photos
Jul 13, 2016 12:27 |  #13
Silver-Halide wrote in post #18065535 (external link)
Shooting at f/1.2 from a half meter away and your motion from breathing can put the eye out of focus, it does not take a large arc or recomposing. Even just moving the AF point from the eye to between the eyes can lose focus, especially when considering also the moving subject issue:
I mean that people move slightly and continuously, even when they are standing "still", including both photographer and subject. Depth of field at f/1.2 or f/1.4 can be a few millimeters in a 1:1 crop or large print. Between the time you lock focus, and the fraction of a second later when you release the shutter, either the photographer or the subject could move or sway enough for something other than what was focused on to be in focus--bangs or eyebrows instead of irises of the eyes, for example.
4,509 views & 1 like for this thread, 9 members have posted to it and it is followed by 4 members.
5d3 AF hit rate
1504 guests, 136 members online
