Trying to get as much performance out of PSE 13.1, where the Healing brush can lag behind this Workstation, and yet have only 1 out of 6 cores is operational.
And its only generally using 1% to 3% of CPU power and 3,8GB RAM out of 32GB!
I noticed it said you should not have your 'Scratch disk' on the OS boot-up drive. But that it must placed on a fast drive.
I have a couple of Samsung 850 Evo 500GB SSD's configured [So relatively quick but not on a par with the Inter 750 PCIe OS SSD] - these are generally used for "Interim Storage" SSDs. Namely I keep the current shoots worth of images on the Intel 750 C drive, work on the edits there, but also copy the shoot to 2x SSDs on the fly, and archive to the 2 HGST 7,200 rpm 4TB back up drives at the end of the day.
So I assume I should place this 'Scratch disk" on the Samsung?
Not really sure what it does, or why I need it as I have 32 GB ECC 2133 Mhz DDR4 RAM - and generally only 3.8% of the CPU is being used ?
I wonder where my bottle neck is , in this system
Any ideas?
Thats about 21 GB, yet Intel XTU showed it using between 3.9 and 6.8 GB ? ( admittedly that only when I looked )
