I followed lots of online guides to make sure the photos were good. But when i export them to Jpeg the file sizes seem small like 3MB
does that seem normal? thanks
Iamjhil Mostly Lurking 10 posts Likes: 1 Joined Jun 2014 More info | Jul 12, 2016 07:39 | #1 I followed lots of online guides to make sure the photos were good. But when i export them to Jpeg the file sizes seem small like 3MB
Jul 12, 2016 07:44 | #2 Yes, that's normal. http://www.avidchick.com
KLR-VA0501 Member 199 posts Likes: 87 Joined Feb 2012 More info | Jul 12, 2016 09:03 | #3 It depends what you're working with. I've got two that I recently exported for prints; both are 3648x5472, one is 28.1 MB, the other is 14.3 MB. Mine are both exported from raw files, not sure if that makes a difference. Ken
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info Post edited over 7 years ago by tzalman. | Jul 12, 2016 11:27 | #4 KLR-VA0501 wrote in post #18064892 It depends what you're working with. I've got two that I recently exported for prints; both are 3648x5472, one is 28.1 MB, the other is 14.3 MB. Mine are both exported from raw files, not sure if that makes a difference. A 20 MP image, which in 8 bits and uncompressed makes a file of around 57 MB, and after Jpg compression is 28 MB? That is compression of only 2:1, possibly the minimum compression that the Jpg format is capable of. Are you setting the LR Quality slider to 94 - 100? That is not the most efficient use of Jpg - perhaps you should read the article linked above by Nathan. Elie / אלי
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jul 12, 2016 14:55 | #5 Note that 100% (LR) and Q12 (PS) is unnecessary for most things. Q10 is more than enough for printing, and prints from a Q8 file will look exactly the same. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
BigAl007 Cream of the Crop 8,120 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Jul 12, 2016 17:21 | #6 I downloaded the test exporter that was used in the linked article, and ran some tests of my own. Not only is the Q10/80 setting visually indistinguishable from the 8 bit TIFF file, but if you load all of the images that are generated in to PS as layers in one document, and set the blend modes to Difference it is virtually impossible to measure the per channel differences in any particular channel. The Thread i created about it may be found here. Since I ran this test I have always used Q10/80 as my default maximum quality output, even for printing.
KLR-VA0501 Member 199 posts Likes: 87 Joined Feb 2012 More info | After reading the article and exporting the same 28.1 MB file with settings of 85 and 75, I see no difference in the image when viewing; same pixel dimensions but the overall size of the file went down to 13.8 and 10.3 for the lower settings. No discernible difference in image quality while reducing the file size considerably. Not sure what I'll use for my default but I'll probably go back to the default setting of 75 but at the same time keep close tabs on the output quality of the images. Ken
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Jul 15, 2016 10:10 | #8 KLR-VA0501 wrote in post #18067673 After reading the article and exporting the same 28.1 MB file with settings of 85 and 75, I see no difference in the image when viewing; same pixel dimensions but the overall size of the file went down to 13.8 and 10.3 for the lower settings. No discernible difference in image quality while reducing the file size considerably. Not sure what I'll use for my default but I'll probably go back to the default setting of 75 but at the same time keep close tabs on the output quality of the images. When you change Quality in the output of JPG files, what you are affecting is the amount of data compression of the file...which is accomplished by 'binning' similar colors more finely or coarsely. Those changes might nor might not be perceptible to your eye, if you look in 'same color' areas like large expanses of sky. For example
...the preceding is only for conceptual understanding and may not reflect the real performance of your software in determining output file sizes. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info Post edited over 7 years ago by Wilt. | I just did a quick test using an image from a Canon 40D using LR3 to output native resolution images (3888 x 2592) ...
(What seems like lots of 'similar color' in fact is not, there is considerabel gradient in the night sky and roof, and plenty of digital noise in the uncorrected image!) You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
| Latest registered member is semonsters 1526 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
