kaitanium wrote in post #18065588
Has anyone have any general thoughts and opinions on this to sway me before i jump into doing this?
I assume the 600ex i has a faster refresh rate at full power than the 430ex iii which could be the dealbreaker for me. Reliability i assume is on par for both. The size of the 430 though is a real plus
Bad assumption that a more powerful flash is FASTER to recycle. Specs from Canon state up to 5.5 sec for 600EX-RT to recycle, vs. up to 3.5 sec for 430EXIII-RT to recycle.
They both ordinarily use four batteries, and the 600EX would take more total electricity per full power flash to output more light, so it make sense it has a larger capacitor to fill up each full power flash from identical sets of 4 batteries. And, at minimum power output each flash takes a minimum of 0.1 sec to recycle.
If you shoot with 200mm FL, the 600EX zoom flash head narrows its beam to suit to achieve a bit more range, whereas the 430EXIII only zooms to 105mm.
