Thread started 03 Aug 2016 (Wednesday) 09:15
ND Filters
DigitalDon
Joined Aug 2012
Post edited over 7 years ago by DigitalDon with reason 'Wrong link'. (2 edits in all)
Aug 03, 2016 09:15 |  #1
Is there a thread on POTN dedicated to ND Filters? Only found a few post.
I know I know these filters are dirt cheap but I wanted to see for myself what a nd filter does before I spen big bucks on a top of the line nd filter.
https://www.amazon.com …age_o03_s00?ie=​UTF8&psc=1 (external link)
I stacked nd 4 and nd 8 and I could still see through them?
(EOS RebelT3i EF-S 18 - 55 IS II Kit) (EFS 55 - 250 mm lense f/4-5.6 IS II) (YONGNUO YN 565EX flash)
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Aug 03, 2016 09:51 |  #2
DigitalDon wrote in post #18085361 (external link)
https://www.amazon.com …F+Concept%7CHoy​a%7CTiffen (external link)
Click the magnifying glass icon in the upper, right corner of the page and put "ND filter" into the search box; you'll get a ton of hits.
An ND filter works exactly like sunglasses do for your eyes; they cut the amount of light coming in, so things don't look so bright. So, you'd use them for reduce the available light when you have particular settings you need to use, in situations (like mid day shooting) where stopping your aperture down and/or using a faster shutter speed are not options.
DigitalDon
Joined Aug 2012
Aug 03, 2016 10:51 |  #3
Snydremark wrote in post #18085398 (external link)
Thanks Snydremark
Dumb a** me thought a ND 4 was a 4 stop, Nd 8 was 8 stops, instead of Googleing ND and a number I should have googled 10 stop ND Filter to get ND 400 or whichever it is, is there anything in photography that doesn't says one thing but means another.
Thanks again for your help
Scrumhalf
Gallery: 158 photos
Joined Jul 2012
Aug 03, 2016 10:59 |  #4
Yeah, everything in photography works in multiples (or fractions) of powers of two. A bit cryptic in everyday terms but what to do? :)
Sam
5D4 | R7 | 7D2 | Reasonably good glass
If I don't get the shots I want with the gear I have, the only optics I need to examine is the mirror on the bathroom wall. The root cause will be there.
Snydremark
Gallery: 66 photos
Aug 03, 2016 11:10 |  #5
DigitalDon wrote in post #18085431 (external link)
Thanks Snydremark
Sure thing; I meant to hit on that but I was posting while getting ready for work and had to run. The other thing to keep in mind is that there are a couple of different ways that companies designate their filter densities. The 4/8/etc like you've found is one way, the other way is what companies like LEE use, where they designate via decimal value. So, a .3 is a 1-stop, .6 is a 2-stop, etc. Mentally, it's easiest to pick a single filter line and stick with it or make sure you're combining lines that designate themselves the same way. Not because it has a better or worse final effect, but because you don't have to do as many mental gymnastics when figuring out what filters you want to stack :)
DigitalDon
Joined Aug 2012
Aug 03, 2016 11:28 |  #6
Thanks guys
flowrider
Gallery: 127 photos
Aug 03, 2016 12:16 |  #7
I bought a cheap ND filter that had good reviews here and online. It's not great but likely better than what you linked to and it's actually glass.
https://www.amazon.com …ID=31P8S5mEh6L&​ref=plSrch (external link)
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
frugivore
Gallery: 11 photos
Aug 03, 2016 12:38 |  #8
Here is an interesting comparison test done at F stoppers:
https://fstoppers.com/​bestfiltertest (external link)
I have a Hoya 4 stop. I think I need a 6-stop if I want to shoot at f/1.4 in sunlight with flash.
gremlin75
Aug 03, 2016 19:59 |  #9
One thing I will say about Neutral density (ND) filters; the vast majority of them are NOT neutral! The cheaper they are and the more light they cut the more color cast they will produce.
Even expensive ND filter can have a large amount of color cast (I'm looking at you Lee big stopper!)
If you're just messing around a few cheap low stop nd filters aren't too bad and the color cast they produce should be fairly correctable in post. But if you know you'll be using them quite a bit or if you need high stop filters get good high quality filters.
I have been quite impressed with the Firecrest ND filters from Hitech. I have a 4 stop (1.2) and 10 stop (3.0) and both have next to no color cast. I do have some cheaper Hitech (non firecrest) filters and my 8 stop is unusable as the color cast is not correctable. Quality counts
1,949 views & 0 likes for this thread, 6 members have posted to it and it is followed by 4 members.
ND Filters
1047 guests, 105 members online
