Thread started 03 Aug 2016 (Wednesday) 17:30
cloudy night sky
andymanty
Gallery: 81 photos
Joined Jan 2014
Aug 03, 2016 17:30 |  #1
cloudy night sky
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/08/1/LQ_806459.jpg
Image hosted by forum (806459) © andymanty [SHARE LINK]
TCampbell
Gallery: 13 photos
Joined Apr 2012
Aug 05, 2016 10:49 |  #2
Very nice... you've got Corona Borealis (the "Northern Crown"), a bit of Boötes, part of Hercules, part of Ophiuchus in the shot.
If the camera had been pointed just a tiny bit higher then you would have captured the globular cluster M13 (aka the "Hercules Cluster") a tight ball of stars that orbits the Milky Way galaxy in a kind of halo region and is home to about 200,000 stars all in one tight spot.
twists ­ n ­ turns
Gallery: 12 photos
Joined Apr 2016
Post edited over 7 years ago by twists n turns. (3 edits in all)
Aug 05, 2016 20:35 |  #3
Nice. Got a similar shot myself a couple of weeks ago il post, hope you dont mind...
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/08/1/LQ_806800.jpg
Image hosted by forum (806800) © twists n turns [SHARE LINK]
Very new to the whole night photography side of things. Just messing about really, but i liked this one...
Im just hoping TCampell will tell me what i have in mine!  :p Googled the Hercules cluster. That's something else!
TCampbell
Gallery: 13 photos
Joined Apr 2012
Aug 06, 2016 14:35 |  #4
twists n turns wrote in post #18087678 (external link)
Hosted photo: posted by twists n turns in
./showthread.php?p=180​87678&i=i50560159
forum: Astronomy & Celestial
You essentially captured the same part of the sky, but with a lower focal length lens - so you have a larger area of sky in your image.
Here's the view of sky in your image:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2016/08/1/LQ_806924.jpg
Image hosted by forum (806924) © TCampbell [SHARE LINK]
The globular cluster M3 and M5 are both in your image. M3 is probably behind the clouds, but I actually do *see* M5 in the image. M51, the Whirlpool Galaxy, is also in your image but appears to be obstructed by clouds. M13, the Hercules cluster, is just a bit outside the frame (off the top edge.)
If you point your camera to the North-East at around 11pm (or later) and you have reasonably dark skies then you should *easily* be able to image the Andromeda Galaxy.
Andromeda is huge -- not just in the sense that it's bigger than our own galaxy -- but also in the sense of how much of the sky it occupies. It's about 3º wide. The full-moon is about 1/2º wide. That makes the Andromeda galaxy roughly 6x wider than the width of the full moon!
twists ­ n ­ turns
Gallery: 12 photos
Joined Apr 2016
Aug 08, 2016 03:37 as a reply to  @ TCampbell's post |  #5
Thanks man! Great info. Def going to have more of a crack at night photos.
2,609 views & 4 likes for this thread, 3 members have posted to it.
cloudy night sky
1011 guests, 108 members online
