I have the Canon 70-200 F4 IS lens. I don't understand what this button is for. I've tried shots on 1 & 2 and don't see any difference. Can anyone explain what it's for?
Aug 10, 2016 07:38 | #1 I have the Canon 70-200 F4 IS lens. I don't understand what this button is for. I've tried shots on 1 & 2 and don't see any difference. Can anyone explain what it's for? Anita W.
Qlayer2 OOOHHH! Pretty Moth! More info | Aug 10, 2016 09:57 | #3 That is correct. Mode 2 is panning mode- turns off stabilization on the axis it detects the camera is moving along.
Aug 10, 2016 11:21 | #4 ok, I was using it to take landscape photos and switched between 1 & 2...no difference. That would explain it! thanks Anita W.
Aug 11, 2016 17:57 | #5 I probably shouldn't say this here but I have had consistently better results on all subjects (especially moving ones) by using the third setting (fourth on the latest lenses) - namely OFF. Faster, more accurate AF, sharper images and no fighting the IS when tracking. You always have IS in reserve for extreme circumstances when it can be a godsend, but if there is any light available I get better results without it. Life is for living, cameras are to capture it (one day I will learn how!).
Aug 16, 2016 13:18 | #6 johnf3f wrote in post #18093047 I have found a marked improvement at focal lengths from 16 to 800mm (+ extenders) hand held and more so when using a tripod. Would you mind elaborating a bit as to which lenses you're seeing this with, and in what kinds of setups (handheld, tripod, etc)? I'm not doubting your experience at all, in fact I've seen it myself with some lenses, I'm just curious if we can narrow the scope a bit. 5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
Certainly! Life is for living, cameras are to capture it (one day I will learn how!).
rent Senior Member 651 posts Likes: 39 Joined Mar 2005 Location: Irvine, CA More info | Aug 17, 2016 16:41 | #8 Tripod = off or doesn't matter if using latest gen IS http://portfolio.alexjiang.com
| Latest registered member is semonsters 1676 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
