Celestron wrote in post #18143863
It doesn't show a map like the CSC does , CSC much easier to understand cause you can see actual clouds and as far as LP if you know how to read the map colors you can see LP effects . Just compare the shaded color to the chart on the side which tells you how seeing is . I can tell if it's going to be a clear night or not .
You're referring to the map link?: http://djlorenz.github.io …/lp2006/overlay/dark.html
Danko's site will show a small excerpt from that larger map based on the location of a known observing site.
As for cloud cover, the Clear Outside chart gives you clouds based on layers of low, medium & high level clouds and then a combined total clouds value.
I check multiple maps if the weather is uncertain for viewing because they sometimes give wildly different predictions.
My favorite tool (which they took away but I think will be coming back) is Wunderground "model" data. This was a feature of the "Wundermap". It used to be possible to view the forecast models (not just the report where they tell if you they think it will be clear vs. cloudy, but the visual "model" where the computer shows the prediction for where it thinks the clouds will be. This was REALLY handy because sometimes an "iffy" forecast really just meant that you are located near an edge where a system might clip just barely to the north or just barely to the south... and if that's the case, I might be able to pick a different observing site and dodge the clouds.
Wunderground simplified their site and took a lot of these more technical features away. I think they were using Google maps and may have switched to a different map (I no longer see the Google maps logo when I view the "Wundermap" feature.) In any case, they seem to have indicated that some of these features will be returning to the new map as they re-develop the Wundermap. I really hope they bring back the modeling feature. That was incredibly useful for planning out observing nights & locations.
