Thread started 16 Aug 2016 (Tuesday) 15:50
5dIII AF point problem
Silver-Halide
Joined Jan 2015
Aug 16, 2016 15:50 |  #1
Folks,
I have a problem with my 5dIII. It started at a wedding over the weekend without any identified cause such as a drop or splash. One of the AF points (2nd from the top, first row left of center) is randomly blinking in landscape orientation. When I turn the camera to portrait orientation, the blinking stops. Turn it back to landscape and the blinking returns. it happens both in red and black--push the AF selection button and the whole array turns red, with the blinking AF point, and also when its back to black. Toggling the M.Fn button doesn't seem to rid it, either. I pulled the battery and that got rid of it for a little bit, but then it came back a few minutes later. AF works with both this problem point as well as with all the points around it, but its annoying and makes me wonder if something bad could be coming down the pipe.
..Anybody?
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Aug 16, 2016 16:15 |  #2
The first answer is probably going to be the same as any other electronic item, try a full camera reset, settings and all, to get it back to factory base settings. See if that fixes it, then go back and reset the settings to what you need.
Silver-Halide
Joined Jan 2015
Aug 16, 2016 16:25 |  #3
Ok thanks. I've forgotten all I've done to really tweak it. I haven't done any manual focus adjustments or anything particularly difficult, but have customized a lot of menus and settings. If nobody else has identified this particular problem before I may have to do that.
Trvlr323
Aug 16, 2016 16:59 |  #4
It sounds like you've just memorized that point as a preferred AF point for easy recall. It is part of the AF system on the 5D3.
Here is an article from canon that describes what you are seeing in the viewfinder as well as how to program or clear the point...
http://learn.usa.canon​.com …emorizing_af_po​ints.htmlp (external link)
Sometimes not taking a photograph can be as problematic as taking one. - Alex Webb
apersson850
Obviously it's a good thing
Gallery: 35 photos
Aug 17, 2016 04:04 |  #5
Exactly that is what I thought about too. I use that feature all the time on my 1DX.
Anders
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 7 years ago by TeamSpeed.
Aug 17, 2016 07:20 |  #6
Certainly sounds like it... :)
The viewfinder display
This has confused more than one EOS shooter, so it’s important to be aware of this feature. Once you memorize an AF point, the Intelligent Viewfinder Display on cameras like the EOS 7D and 5D Mark III shows you that point, so that you know where you can jump back to by pressing the control you’ve assigned for return to a memorized AF point.
EOS 7D does this by showing the memorized point as a tiny square on the focus screen, while your active AF point (any of the remaining AF points) appears as a normal sized square on the screen.
With the 61-point AF system, however, the memorized AF point appears as a second normal sized, single AF point… but it blinks on and off. This blinking AF point simply tells you the location of the memorized point, so you can place it upon a subject as you move your thumb or finger to the control you have assigned to switch you to that new AF location. Unfortunately, if a shooter forgets that he or she has memorized an AF point, that blinking point in the finder may lead them to think something is wrong. It isn’t. And if a memorized AF point is no longer needed, it can be easily removed.
Silver-Halide
Joined Jan 2015
Aug 17, 2016 17:50 |  #7
Thanks all. I certainly didn't go into any menu to set a point as an AF. I think when it happened I was toggling the M.Fn button and perhaps my spastic fingers magically entered the secret combo of buttons and it set the blinky point.
Canon was quick enough to answer my phone call and unfortunately this particular rep was quick enough to push me to resetting everything, which did get rid of it, along with all the rest of my settings. the audible "beep" was on with auto focus and BBAF was disabled. Easy enough to reset. I hope didn't miss anything else  :p
apersson850
Gallery: 35 photos
Aug 18, 2016 10:19 |  #8
You don't register an AF point in any menu, but by pressing two buttons at the same time. Exactly which buttons depend on the particular camera.
Anders
2,637 views & 0 likes for this thread, 4 members have posted to it.
1504 guests, 136 members online
