Blackey Cole wrote in post #18108889
If I was going to build a computer to run OS X is there hardware that mimics the apple hardware so it will not be hackintoshing but building a non apple machine? I'd like to build the best I can as far as reliability and speed. Most of the Apple hardware is not very upgradable or expandable and I want something that is. Most of the new Apple hardware is either packaged in the monitor or in a box big enough for the existing items and not very expandable or upgradable and if you do you void the warranty. Like adding a second hdd to a mini I think upgrading the memory was allowed. Plus the cost of the Apple machines are so much more than the equivalent PC hardware.
I'm figuring any thing I build will boot win 7 and run it ok with lirttle trouble getting drivers for everything when I need the PC which is less and less right now the only thing that I don't have both OS versions is Microsoft flight sim. I have both versions of X plane so if I learn it I may go OS X all the way.
One more thing Will OS X run multiple monitors? I have a very good video card that will run four monitors IIRC. I might get it to work with OS X if so will the OS support multi monitor setups and how about multi video cards?
If you want to run OS X without it being a hackintosh, the you have to get an Apple Mac. It's really unfortunate that Macs are no longer as expandable or owner customizable as they used to be. I have an old 2008 Mac Pro which I bought at a discount when a newer model came out. Over the years, I have replaced the HDD to SSD, added more internal drives (4 total), added another DVD writer (2 total), added 16GB of memory and added another video card as well as a few other cards, like a USB 3 card, to it. And it's still going as strong as ever thanks to its dual quad-core processor.
I have 4 monitors hooked up to it, including a Wacom Cintiq, so, yes, Mac OS X does support multiple monitors. I also have Windows 10 installed because the Mac is dual bootable. I boot up Windows 10 so that I can run DCS World on it. If I need to run any other Windows app which is not hardware dependent, then I run Windows 10, 7 and/or XP as a virtual machine in VMware Fusion running on OS X. I can also run Mac OS X as a virtual machine so that is how I test new versions of OS X before physically installing on my Mac.
MyMac Pro is still running so well that I don't foresee replacing it for a while unless it dies on me (knock on wood!). I dread the day I'll have to replace it with a newer Mac Pro, though, since I know I'll have a harder time expanding it or customizing it.
