Thread started 29 Aug 2016 (Monday) 22:00
Composition C&C
sued5320
Gallery: 6 photos
Aug 29, 2016 22:00 |  #1
I'm following an online tutorial/class on composition. One instruction was to view images in black & white to focus more on tones/shapes/lines. I headed out yesterday morning and have 3 images from my composition practice. Please provide constructive critique on composition.
1.
IMAGE: https://c8.staticflickr.com/9/8525/29328183735_bbecb4b4d1_b.jpg
2.
IMAGE: https://c5.staticflickr.com/9/8478/29040981820_76128a9003_b.jpg
3.
IMAGE: https://c6.staticflickr.com/8/7774/28707786333_30e077d6e1_b.jpg
Sue MyFlickr (external link)
EOS 450 XSi * 50 1.8 * 70-200 2.8L IS II * Tamron 17-50 2.8 * 85 1.8 *EF-S 10-22
Nothing happens when you sit at home. I always make it a point to carry a camera with me at all times....I just shoot at what interests me at that moment. Elliott Erwitt
Alveric
Gallery: 38 photos
Post edited over 7 years ago by Alveric.
Aug 30, 2016 01:12 |  #2
The yellow in the sign on #1 could be brightened a bit and then the composition would make more sense. It's not bad, but I'd like to see the full frame image: the crop makes me wonder if you cropped as a post-composing crutch: not unlike cheating.
#2 has no focal point really. Don't think it works as an image.
#3 is not very interesting (subject matter kinda boring), but it's not bad composition-wise. Neat idea of lining the edge of the cultivated field with the contrail, and nice work of having the more interesting half of the landscape (the sky) occupy two thirds of the frame.
Qbx
Gallery: 52 photos
Aug 30, 2016 02:15 |  #3
I agree with Alveric's critique. I would add that #3 might make a better composition if cropped to a horizontal with the sky being 1/3 of the image. I don't find the sky to be particularly interesting. If you wanted to add interest to it, you could pump the contrast. If you had moved camera right a few steps #3 might have been a better composition as the front row of corn would not be running straight down the middle of the frame.
-- Image Editing OK --
sued5320
Gallery: 6 photos
Post edited over 7 years ago by sued5320.
Aug 30, 2016 13:24 |  #4
Alveric wrote in post #18111035 (external link)
Qbx wrote in post #18111056 (external link)
Thank you for the comments.
#1. I'll see what I can do on brightening the yellow. I adjusted the available sliders/curves in DPP 4, pulled the saturation to zero, and nothing else. I admittedly don't know the proper way to convert to black and white. As far as the cropping, I did crop out some on the top and bottom as it wasn't adding to the image. I can repost the uncropped version later.
#2. Aren't the corn tassels the focal point? There's nothing else in there but the sky. Maybe the color version is more interesting.
#3. I cropped a bit on the right side as I thought this looked more balanced with the darker trees versus the corn. I also cropped my shadow out of the bottom. I'm sure I have one taken horizontally that I can post later as well.
Tom ­ Reichner
"That's what I do."
Gallery: 213 photos
Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot
Post edited over 7 years ago by Tom Reichner. (2 edits in all)
Aug 30, 2016 13:46 |  #5
sued5320 wrote in post #18110916 (external link)
1.
I really like the compound curve, or "S" curve, created by the top of the treeline. This keeps the horizon from being a straight line, which is always so boring.
Alveric
Gallery: 38 photos
Aug 30, 2016 14:24 as a reply to  @ sued5320's post |  #6
Desaturation is the simplest way to convert to monochrome, but it's also the one that gives you the least amount of control.
Best thing to do is to use the RAW processor's Black & White option (if it has one) so that you can manipulate the colour channels independently, brightening and darkening colours at will.
http://www.cambridgein​colour.com …als/color-black-white.htm (external link)
RE: the tassels: Yes, I can see that they are the subject you were focusing on, but there's way too much clutter everywhere that they don't really stand out –even being in focus where everything else isn't doesn't help them.
Left ­ Handed ­ Brisket
Gallery: 15 photos
Joined Jun 2011
Post edited over 7 years ago by Left Handed Brisket.
Aug 30, 2016 16:20 |  #7
Alveric wrote in post #18111539 (external link)
yup. the first image desperately needs that kind of work to change the tone of the grass and road ... one of them needs to be darker or lighter than the other. Would like to see some detail in the sky too. If there's none there, you should get your hands on a polarizing filter (CPL).
edit: i didn't notice the truck in there ... meh, kinda needs to go.
Kind of agree. i think this image is close, but I don't like the 4:3 aspect ratio, or whatever it is something wider might be more interesting. Plus the contrail is kinda distracting. There is some psycologial stuff with angles where people often perceive the left/higher to right/lower angle in this image to be descending. Fine if that is your intent, but ascending, left/lower to right/higher, might give a little more umph.
third image is the best of the set. I can't really decide if i like the vertical contrail that continues to split the frame with the edge of the corn. I might give it a little photoshop work to make it less pronounced.
sued5320
Gallery: 6 photos
Aug 30, 2016 21:53 |  #8
Tweaked #1 - also removed all the cropping. I used the Monochrome conversion and the filters in DPP which gives a little more flexibility with the tones. I have a PS Elements class next week and hope to learn how to do more there. I think the cropped version is better.
IMAGE: https://c1.staticflickr.com/9/8137/28728634944_a95f2f651b_b.jpg
#3 Removed cropping from the right side so the field edge/contrail is in the middle.
IMAGE: https://c1.staticflickr.com/9/8267/28728633104_d649bd71bf_b.jpg
New image #4 as suggested by Qbx - like #3 but horizontal with sky ~1/3 of the image. I only cropped down from the top - nothing from either side or the bottom.
IMAGE: https://c2.staticflickr.com/9/8549/29273204761_112e73576e_b.jpg
twopinetreesphoto
Joined Sep 2009
Aug 30, 2016 22:20 as a reply to  @ sued5320's post |  #9
I'm sorry, I'm just not a huge fan of the set. I agree mostly with what's been stated.
#1 - for me I see the curved road, but it all gets lost with the surrounding grass, its all gray. Then guardrail is like a neon sign bright. The road S curve is the subject, and its totally lost with everything else. I could care less of the sign, honestly I think it detracts. What I've heard is anything that doesn't ADD to the composition detracts. Simple is better, try cropping it out to say a 4x5.
#2 - sorry, don't see much here.
#3 - I might say you went the wrong way, I'd try cropping most of the ground and leave most of the sky. Again, the corn and the grass all kinda blends, and its right in the middle of the shot, its just muddy. The sky and clouds have clear lines, but are close in brightness. I'd try cropping the ground, and dark the blues and up the white point to push the clouds brighter.
Good works in progress.
Gallery: 15 photos
Joined Jun 2011
Aug 31, 2016 07:18 |  #10
sued5320 wrote in post #18112026 (external link)
the road is probably already grey so it will be hard to change the tone of it during the conversion. You might however get a little movement from the blue and cyan slider since the sky is probably reflected in it a bit.
if you move the cyan and blue to the left for the road, move the green and yellow to the right for the grass. Or vice versa.
best advice i ever received with color correction work was to take it too far and work your way back to where you want it. Slide those sliders all the way out and then work back, it will make the transition easier to see.
3,019 views & 2 likes for this thread, 6 members have posted to it and it is followed by 3 members.
Composition C&C
1320 guests, 123 members online
